Broken - Computers & Internet
    Problem Solver:
  • 10 Answers
Just fix them.
Posted on Nov 22, 2009
It dosent heat
Possible reasons:
1. High voltage capacitor is broken.
2. High voltage diode is broken.
3 One of three thermal fuses is broken.
4. Magnetron is broken.
5. High voltage transformer is broken.
6. One of three door sensors is broken.
7. Some relays broken.
Sep 23, 2015 | Microwave Ovens
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
How to remove broken bolts from power steering
you can use easyout.if there is room to drill middle of the broken bolt easy out will help you out
May 05, 2014 | 1997 Buick LeSabre
I have 1998 ford f150 5.4 bio fuel 2 wheel drive automatic truck I was going down the road and without any warning it stopped moving it goes into all gears but does not move what do you think the problem...
No mention of noises so I'll have to guess.
If it's a recently repaired transmission, torque converter/starter ring nuts or bolts fell out.
IF: Standard trans:
Clutch completely shot or Pressure plate broken/locked short of contact. Output shaft broken, driveshaft/u-joint broken. Pinion gear loose/broken.
IF: Auto trans:
Overheated trans led to blown O-rings internally causing failure of the clutches/components. Output shaft broken, driveshaft/u-joint broken. Pinion gear loose/broken.
Sep 30, 2013 | Transmission & Drivetrain for Ford Transit...
How do you fix a broken hyperlink?
Step 1:
A broken link on your website is like a broken promise to your visitor: You did not provide the content you said you would. Broken links might cause some visitors to question your professionalism, competence or intelligence. Don't disappoint your visitors. Make certain that all the links on your website actually work.
Use your Web browser to go to a free online link checker. Options include the W3C Link Checker, Iwebtools' Broken Link Checker or 1-Hit Broken Link Checker. http://validator.w3.org/checklink , http://www.iwebtool.com/broken_link_checker , Find and remove broken links in your website http://sixrevisions.com/website-management/find-remove-broken-links/ Broken Line checker http://www.1-hit.com/all-in-one/tool.broken-link-finder.htm Enter the URL of the Web page you wish to check. Click the "Check" or "Check Links" button to begin the validation process. Review the results once the link checker has finished its work. The report will list all the broken links the checker was able to find on that page. The W3C Link Checker report also gives you the line number where you might find the broken link in the original HTML code. Open your Web editor and load the page you just checked. Search for the broken link. If you have trouble finding the link, try copying the broken link from the report, then use your editor's "Find" function to quickly locate it. Find and correct every broken link listed in the report or remove the links if they no longer are needed. Save the edited page. Open up your FTP (file transfer protocol) application and connect to your Web server. Transfer the edited file from your computer to your Web server. Log out of the server. Recheck the the Web page you just uploaded. If this page passes with no problems, repeat the process for each page in your site that has links.
Feb 13, 2013 | Microsoft Windows XP Home Edition
My heart is broken
time will heal a broken heart.. get used to broken heart and your heart will never be broken again..
May 30, 2010 | Acer Aspire One PC Notebook
Lcd Screen Broken
is the display is broken or the screen is physically broken,if display is broken we can check the and isolate that some part is gone bad in the computer or the issue is with the monitor.If screen is broken physically then nothing can be done...really sorry the monitor needs to be replaced
Nov 29, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Not getting hot
if your dryer is gas-dryer:
1-thermal fuse is broken.
2-ignitor is broken.
3-sensor flame is broken.
4- gas valve is broken.
if is electric dryer:
2-heat element is broken.
Oct 06, 2009 | Dryers
My stroller has a broken axle and broken bracket
I called Bumbleride and they sent me a new frame.
Jul 08, 2009 | BumbleRide Indie Twin-Spice Jogger...
Broken screen
What do you mean,it show a broken screen,dose it say broken screen or is the screen broken?
Jul 09, 2008 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
