Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
My bissellproheat2x not sucktioning - Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
  • 276 Answers
Check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If your machine continues to not spray, Contact BISSELL consumerservices at www.bissell.com.
Posted on Aug 26, 2010
No soap coming out on my bissellproheat2X pet
Sorry to hear your ProHeat 2X isn't releasing formula. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1131&cid=ccsocial
Dec 28, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
Why does my miele 700 revelution hoover keep cutting out? The bag is not full just loses power?
  1. i have a miele revolation hoover, it doesnt pick up. it has hardly no sucktion. where and how do i get the filter out to clean it??? it was given to me working. ive changed the bag so thats not the problem. and checked the hose. still no joy. need sucktion.. Thankyou jacqui
Jan 01, 2010 | Miele Revolution 600 Bagged Canister...
Hoover vacuum carpet cleaner will not sucktion (sic)
No, this cleaner uses no belts.
If you are having a suction problem, first check that the lid on the recovery tank is lined up to the tank when installed to get a good seal.
Second, remove the tank and make sure the round black rubber seal is present on the pipe from the base that aligns with the bottom of the recovery tank. That seal connects the vacuum from the motor to the recovery tank.
Oct 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My dyson works only without the prefilter
Dyson's are terrible vacuums. Sure they look cool and may work for a couple months but they start to "fall apart" no more than a year. If you have pets, then i suggest you spend the money on a machine that won't break down or give you silly issues like a Dyson would. This vacuum is called a Miele Cat & Dog.
http://www.thinkvacuums.com/miele/catdog.htm
Jul 27, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brush spins but the the dirt is not getting into the bag. i cleaned the hoses now it's not sucking anything up.
If the motor is running you should get some kind of sucktion, if no sucktion or wont blow any air out, check the house making sure is clear of any obtruction, the best way is looking in the house by have one person hold one end and other pull the house straight and look to see any obstruction. if it seem clear, check the motor attach to the fan, yep you have to take the cover to the motor off with phillips screw driver in order to see what causing motor not to **** although the motor may not be attached to the fan; could be loose and not spining the fan to create any sucktion. hope that help some..good luck
Jul 12, 2009 | Vacuums
My kenmore hida filter vacuum cleaner no longer has the sucking ability it used to have. It is only 4 years old and has worked extremely well up until this week. The motor is functioning well, as is the...
well i've hade one come in a while ago and it didn't have good suction so I looked at the bag it was buljing w/ dirt so I put a new bag in it and it had better sucktion but still not good enough so I cheched the fabrick filter and it was dirty too so I washed it and it had even better sucktion so try the paper filter on the end too and if your vacuum still haves bad sucktion try looking if the hose is clogged buy putting your mouth on the end and blowing through it i recomend whiping the end off befor blowing if hard to blow it is clogged, if clogged i would put something thin like a metal rod or or a stirty stick to push the dirt out i'm sorry if my info didnt work out :D
Jun 12, 2009 | Kenmore Whispertone 23312 Bagged Canister...
No suction on wind tunnel vaccum cleaner
Your brush might be clogged with hair. while uplugged, flip over the vacum and check to see if there is any hair or string wrapped around the brush...
Jun 03, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Not getting sucktion to the hose. not picking up dirty water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
7t897
Dec 22, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
76 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
