Question about Music
I tune on my frontman 25r and when I input I dont get any sound other than hiss.I tried two different cords and guitars but nothing but his. what should I do?
  • Music Master
  • 5,603 Answers
It sounds like a failure in the preamp stages, but fortunately you can do a lot of troubleshooting externally.
Drive the "power amp input" jack with another source of audio that has some reasonable output... like a small CD player. If this works (no mind the level, just the quality, that will verify if the power amp is OK.
If the power amp is OK, the use the preamp out to another amplifier.
If it is OK, then the Power amp input jack switch MAY be bad, When nothing is plugged into these, the preamp is sent to the power amp by a switch on the power amp input jack.
If you do these tests, you can email me the results and I will give further tests to run.
Posted on Nov 19, 2009
SOURCE:
Fender Frontman 212R crackling noise
After ruling out guitar wiring or bad cables...
Try the 2nd input on the amp
also
Is it on both channels, or just one?
Nov 01, 2013 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
I have a little Fender Frontman Reverb, 15Amp, a versitile and handy amp, closed back and dual front ported with extension and headphone outputs. Went to use it one day and as soon as I turned it on I got...
It sounds like one of the preamp valves is faulty or other components in that area of the circuit causing a positive feedback loop which is generating the noise. You need to take it to an authorised Fender repairer in your area. Whereabouts are you?
Dec 13, 2017 | Fender ® Frontman 15R Electric Guitar...
I have a Frontman Fender 25R, it has a power, the auxilliary input is working (the RCA, red and white ) sound is produce, when I plugged an electric guitar on the 1/4 input there is no sound coming...
You actually have the "B" version as the original 25R doesn't have RCA jacks. Anyway, on with your problem...
I want you to do a test: With a set of headphones plug them into the preamp output and then play your guitar... don't expect much loudness, it may be very faint and will ONLY be in one of the sides of the headphones. This tests the preamp section... have the guitar volume wide open.
IF you can hear the guitar that way, then the switch contact on the PA INPUT jack (not the preamp output) is not making contact. These jacks are really poor and the problem is not that uncommon. Fix is to open the unit and increase the spring tension on the contact or replace the jack. Never use the jack as they worsen evertime you plug something into it.
Note that the failing switch symptom MAY be broken soldering in the vicinity of the jack so look for that also. And also check the soldering of the guitar input jack as that is a common problem. Always loop your guitar cable through the handle so tripping over the cable doesn't break the jack by yanking the plug sideways... another common problem.
Mar 25, 2011 | Fender FrontmanTrade 25r Combo Guitar...
When i turn up the lead knob there is a loud hissing sound
That is indicative of the statistical electronic noise common to amplifiers. It depends how loud it is relative to the program level. If you get no output while this is turned up, then likely the input to that section of the circuit has failed and that will worsen the noise problem. At wide open you can expect to hear some hiss... probably an annoying level if you are close to the unit. This statistical noise is a problem that plagues engineers and part of it is due to the laws of physics... there are some chips that have better noise performance, but none can totally eliminate it... you can't fool mother nature as they say.
It is always important to balance the gain of the inout preamos against the master volume. MOST of the noise is generated at the input preamp area rather than the power amp, so make sure you have adequate master volume set.
Feb 11, 2010 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Hiss in new fender frontman 65R. Can't seem to dial it out in either input.
A certain amount of "hiss" is present in electronic amps due to the statistical noise in electronics.
The hiss should be WELL below the level you get when playing. If you put you ear to the speaker, expect to hear some hiss with nothing plugged in. Ten feet away it should be very faint.
Dec 30, 2009 | Fender Music
Music Logo
128 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
