Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Further investigation, unplugged unit, plugged back in, hit power button. No picture, but stand by/power LED flashes 15 times rapidly, then flashes 4 times repeatedly. Any ideas greatly appreciated. Thanks, Brian
  • 1 more comment
  • brian_ruse Nov 19, 2009
    Hey there: Copied from "Understanding Sony Blinking Codes" - Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
    Any thoughts?
    Thanks,
    Brian
    Any thoughts?
    Thanks,
    Brian
    Thanks, will try that in the morning...
  • 273 Answers
That sounds like a power supply problem
and may tuen out to be a defective flyback transformer
Posted on Nov 19, 2009
Testimonial: "Thanks, will try that in the morning....."
  • T.l. Moore
    T.l. Moore Nov 19, 2009
    verticale can cause this you may look to see if you have any carcks on the solder joints of the ic first then you will have a better idea where to go next then
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Won't turn on
Can u tell me model no and brand name so that i can help u sir..
Sep 03, 2008 | Samsung PCN5425R 54" Rear Projection...
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Factory reset password admin
Below are the steps in performing the factory reset
• Unplug the power from the system.
• Hold down red reset button on back of system.
• While holding the reset button plug the power back into the system.
• After about 7-10 seconds the LED on the front of the system should start flashing rapidly.
• When it starts to flash rapidly release the reset button.
• This should reset the system. This should take about 5-15 minutes to reset and reboot. If this is done correctly it should come up with the initial configuration screen
The default admin password after the factory reset is 1234
Aug 01, 2013 | Samson Technology LifeSize Passport with...
How to solve my d-link issue?
You can try to reset the router.. While it's on, press the reset button for 15 seconds (do not release), then unplug the power cord, release the reset button, count 15 seconds then plug the power cord back, then press the reset button again for 15 seconds. Then try to reconfigure the router.
May 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
FAST BLINKING GREEN & WON'T POWER ON
I had exactly this problem. After plugging and unplugging it multiple times over several weeks (even plugging it in quickly after it was unplugged but with the green light still flashing as suggested here) all to no avail, it just started working on its own one day. It worked for a few weeks and then the problem re-appeared.
InFocus tech support recommended:
1. Check whether the lamp door is securely closed.
2. Check the color of the LED and the number of time it blinks. (For me, a very fast almost flickering flash)
3. Does the fan operate? (My fan would go on when plugged in)
4. Remove the lamp module, shake it gently and reseat the lamp module.
For me, these steps did not work. InFocus then recommended that I send it to ProjectorDoctor http://online.projectordoctor.com/, and it was diagnosed with a bad power supply. $395, but it is fully functional again. Good luck.........
Jul 24, 2008 | InFocus ScreenPlay 7200 Multimedia...
Power problem
Most likely the convergence ICs are bad. These aare large black ICs attached to a heatsink. They will be marked STK393-110 and have about 15 pins or so. Replace these and check the fuses marked F9A01- F9A06 on the same board. Replace any open fuses after the IC replacement and report your results here.
Dan
Apr 21, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
196 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
