While watching TV the set shuts itself off,at first I thought that the fan was not working but it,s fine, then I thoughtcould it be a weak lamp , it was only replaced about 11 months ago.
  • 5,138 Answers
It could still be your Lamp even brand new ones can be defective!
Posted on Nov 19, 2009
Panasonic TV slow to turn on, works fine after it turns on.
If you have to try to turn it on several times it is power supply related.
If dirty inside on fans etc it would cause set to shut down(the set monitors the fans for speed)>
I would suggest (take it outside) using a air compressor and cleaning the entire set out.
Lamps do fail---average life is 2000 hours for a original lamp and much less for a generic one.
If picture comes up try to watch the light from the lamp---if dim at first and then slowly comes up---it could be the lamp or the ballast the set uses to power the lamp.
Jun 10, 2012 | Panasonic Televison & Video
Replaced lamp on Sony KDS50A2000 and now it shuts off and on every couple of minutes. I used the Menu-Settings-Lamp command and no change. The green light stays on and the sound is also still on. The lamp...
Your tvs lamp is getting over heated. There will be a fan for colling the lamp. if the fan doesn't work properly the lamp will get over heated and the will switch off itself to avoid further damages. Do one thing, Remove the fan from the tv. In the fan there will be a specification sticker. Remove the sicker. Now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. You can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the tv. power ON the tv and watch. If the fan is available then try to replace the same. it will not cost a lot. just watch the following video for oiling the fan. its for a PC fan same for all dc fans.
ok
Apr 01, 2011 | Sony KDS-50A2000 50" HDTV
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Samsung dlp tv turns on works fine but after 15 minutes turns itself back off
This happens due to increasing heat in tv, check exhaust fan is running and throwing hot air out of tv, check temp sensor is working fine mounted on lamp housing.
When did you replaced lamp last time in tv?
A weak lamp also does same problem.
Aug 24, 2010 | Samsung Televison & Video
Tv turns off for a minute and comes back on
if tv turns On itself after shuts down then its symptom of weak lamp as current lamp is reaching to end of its working life, tv requires lamp replacement.
Lamp replacement procedure would be written in user manual and its easy. Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a sony kf50xbr800. This TV was purchased new in 2001. After 5 1/2 years the lamp had to get replace. TV been working good till now. While watching tv it will go to stand by mode, after about 2-min's...
The thought is that it needs to be either cleaned out. Dust build up in it's air intake filter or you probably need another new lamp. Usually when these set's shut themselves down is because they are overheating or they can't maintain the voltage to keep the lamp lit.
Blessings,
A/V Media Tech Guy
Nov 25, 2009 | Televison & Video
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
Sony Grand Wega KDF-E50A10
The lamp light does not have to flash on this set for it to be the lamp, and most likely it is just that, the lamp. These sets when the lamps get weak they will do exactly what yours is doing.
Sep 07, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
