Question about Microwave Ovens
Dryer seems to be heating but cloths are not getting dry hardly any lint on cleanout screen
  • 68 Answers
Is the air venting all the way to the outside? If you ducting is clogged, dry times will be much longer. You may also be seeing steam come out the door if you open it halfway thru the cycle if vent is clogged. A crimped hose between the dryer and the wall can cause a similar problem. A clogged vent can also be a fire hazard.
Posted on Nov 19, 2009
I was washing the Frigidaire microwave today, and now the buttons do not work. I see the time, and the light turns on; I unplugged the microwave and plugged it back again, and the buttons still do not...
Some moisture has probably made its way into the touch pad. You might try heating it a little with a blow dryer on low heat to try and dry up the moisture inside the touch pad or just unplug it for a day or so and see if it will dry up on its own. If it does not start working the touch pad would need to be replaced. Hope that helps.
Aug 30, 2011 | Frigidaire Microwave Ovens
Not drying clothes. Have checked all filters and water tank. Still not drying :-(
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 21, 2011 | Microwave Ovens
Sprayed inside to clean now it sparks when i start it
well done you! you just shorted out the megantron it may dry out if you leave the door open but if its sparking you may well have done it in for good, never spray any thing inside a microwave!!! only ever wip it down with a damp cloth or better still if its gruby and its hard to get this dirt off put a bole of water inside and heat it up the steem will do the cleaning for you then,,,all you can do now is dry it out realy well before you try to use it again and keep your fingers crossed it works ok,,,
Jan 24, 2010 | Kenmore Microwave Ovens
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
My Kenmore Elite HE3 dryer is very slow at drying clothes even at the highest temp and seems to be getting worse.
Best guess is your dryer vent might be blocked. Check to ensure the vent hose is clear of lint all the way to its outlet.
Dec 19, 2009 | Microwave Ovens
My electric dryer is takeing to long to dry clothes.
If you are experencing longer dry times, the following link will explain what to do:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Read through the link provided and let me know if you have any questions. Please post back with a model number if you do. I hope this helps you.
Dec 15, 2009 | Microwave Ovens
Matag Dryer sounds like it has a tennis shoe in it.
Bad rollers or blower wheel is worn out.
Nov 15, 2009 | Microwave Ovens
GE Spacemaker XL1800 (jvm1850sh06) problem
Use a hair blow dryer to dry out the underside of the microwave. After you are convinced that it is dry you may operate it again.
That said, if it still is acting up read this:
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Aug 06, 2009 | Microwave Ovens
Dryer runs has little heat takes longer timer to dry
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Mar 14, 2009 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
60 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
