Question about Gateway 7405GX Notebook
Water on the brain???
My laptop got wet while still plugged in. It smelled like an electrical burning wire or something. I took out the battery, waited for a few days (thinking it would dry). Still does not work... nothing. Any ideas... Yes I know Idea #1... electric + H2o = knuclehead.
mike g.
  • 1 more comment
  • miikg Jan 11, 2008
    Can't figure out to take it apart without taking bottom screws etc.....
    thanks, it worked...
  • dindin516 Feb 09, 2008
    my whole gateway laptop got soaked... it even got wet inside the screen.. my BF took it apart and we blowed dried it for a while.. but it's still not working. We didn't take out the keyboard though.
    Genius:
  • 1,067 Answers
U can take it apart make sure use blow dryer in it for litte wile pop off top cover thats napes over screen hinginges then remove keybord
Posted on Jan 11, 2008
  • Anonymous Jan 11, 2008
    if not sell it for parts on ebay screen ram battery power keybord cpu everting acept mobo im sure is ok
6ya staff
SOURCE:
My charger Wont start. Has new battery. Everything else seems fine. Changed the #9 and 22 fuse. Still wont start
Fuses don't make a burning smell when they blow. Yours is far more serious, something has shorted out and irreparably damaged an electrical component or part of the wiring harness. You need a mechanic, preferably at a dealership who have the diagnostic equipment and vehicle history to know where to look.
May 27, 2016 | 2009 Dodge Charger
Dryer smelled like smoke and hose filled with water
Something is plugged dryers vaporize wetness not create water
make sure all ventilation is clear
Apr 02, 2014 | Samsung Dryers
Xantrex inverter/ charger smells like burning electrical
I would call or e-mail the manufacturer of the inverter. The dealer or dealers may know the issue but likely the manufacturer will be more help.
Some devices like an inverter will have a smell in the beginning, power supplies are like that. You said that the inverter didn't get hot but smell indicates something is hot.
Apr 13, 2017 | Xantrex Electronics - Others
Have electrical issues with 1996 T&C van. Problem with Remote Starter and smoke and smell of burning rubber. Had to disconnect battery to get the van to stop trying to start. When i drove it home, it...
Yes it is . The remote starter wire has touch together and is wanting to start the starter, they have shorted together, The burning rubber smell is the wire melting due to the electrical short. Take the remote starter out plus the push button and reinstall using new set of wire And if you decide to install a new remote starter youll have to install a fuse in line with the positive wire.
Apr 24, 2011 | 1996 Chrysler Town & Country
OUR WATER HEATER IS BLOWING FUSES ..
1) Turn off power before touching water heater that is shorting or wet or was flooded.
2) Circuit breakers & fuses blow because of heat. A short will cause heat. Tighten screws on terminals inside box, listen for crackling sound/burning smell from loose-fitting parts.
3) Easy test for circuit breakers: move water heater wires to another same-size breaker. If same-size does not blow, then problem is breaker.
4) A short between fuse box and water heater could be gnawed electrical wire. Inspect wire.
5) Wires have size markings. 5500 watt water heater needs #10 wire. 4500 watt water heater needs #10 wire but can work with smaller #12 if distance is not long. See label on side of heater for wattage, voltage, etc. Element wattage is water heater wattage even with 2 elements.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
6) Short inside water heater can be elements or thermostat. Open covers and inspect parts for burning. Screws should be very tight against copper wire. Sediment could fill bottom of water heater cause lower element to short.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Sep 16, 2010 | Little Giant Water Heaters
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
Our dryer gave out a burn smell like a belt had broken, and even though plugged in, it will not come on. We took it a part some and didn't see anything wrong. We only took down the front facing to see the...
Dryers have a thermal fuse... typically a ceramic assembly 2-3 inches filled with resin and wires attached...usually near the motor. This may account for the burn smell. Turn the power off and replace .
Dec 08, 2009 | Crosley CDE6000 Electric Dryer
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Dryer runs intermittently
"Could the cord/plug and/or receptical be bad and need replaced or is it likely to be something in the dryer's internal wiring?"
Yes, that electrical smell and the dryer not working are all signs of a bad motor.
"I noticed that the plug looked like it was somewhat scorched."
I would replace that plug. This is how electrical fires start.
Dec 21, 2008 | Dryers
Open Questions:
See all Gateway 7405GX Notebook Questions
Gateway 7405GX Notebook Logo
59 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
