Question about Sharp 32L-S400 32" TV
TV Turns Off
My 32in Sharp tv, model number 32L-S400B turns off after using it for awhile.  Then it wont turn on again.  After I leave it off for days it tuns on again.  Help!!!!
Sarita
tv will not turn on at all.checked fuse and it's good,what else could it be??
  • nievescarmen Mar 20, 2008
    my turns on but immedietly turns off what is the problem
  • Anonymous Mar 21, 2008
    32"in. tv shuts off by it's self, i have to unplug it, plug it back in, then it will come on for a couple of seconds - minutes, and shut back off.
  • 129 Answers
Good day.
Yuor TV has an issue particularly in the power supply section with regards to the loose components. This issue can be best addressed by having your units' circuitry be resoldered before it could damage some parts.
Response is higly appreciated.
chris
Posted on Mar 29, 2008
Sharp TV Model 32L-S400B - Reprogram Channels
Download the user manual to your Sharp TV by this link. It will ahve all details. OK?
May 21, 2012 | Sharp 32L-S400 32" TV
My 26" 1997 Sharp T.V. model #25H-M60 turns off by itself and won't turn back part of the time.
First thing if you are able is to unplug set and remove rear cover (lay set face down on a padded surface).
entire main board should be able to be seen or released so it slides out--take a very careful look at flyback and rest of board for any cracked or bad solder connections.
One bad connection (age) can cause this.
5_21_2012_3_10_50_pm.jpgtypical high voltage transformer which is also called a flyback transformer.
May 20, 2012 | Sharp 32L-S400 32" TV
SHARP 32L-S400B SHEARED OFF CABLE CONNECTOR FROM INSIDE TV TO CABLE .CAN IT BE REPAIRED INEXPENSIVELY?
I have the same problem. Do not have any idea on how to fix it without probable major expense. I have to connect cable box to RCA inputs which require the dvd player to connect with the front inputs...very inconvenient! Hope someone has an answer to this problem.
Sep 04, 2010 | Sharp 32L-S400 32" TV
My sharp 32L-s400b will shut off after it warms up and will not come back on until unplugged for a short while to cool down
What I can think of is either the main filter capacitor is dried up, I had a set that would stay powered on til it warmed up then shut off and the main filter cap was the problem. Or the tv could have a thermally induced shut down, or the circuit protection kicks in due to excessive voltage. A component is defective and excess voltage is happening and the tv shuts down to prevent excessive X-ray emissions or damage to other components. You should open up the tv, be very careful and if you don't feel comfortable, have someone with more experiance or a shop look at it. Look for any blown or burnt components. Also listen for any weird or funny noises inside the set.
Mar 12, 2010 | Sharp 32L-S400 32" TV
TV TURNS OFF BY ITSELF
Sounds like the Startup Relay is dropping out, you will need to replace it.
Mar 28, 2009 | Sharp 32L-S400 32" TV
Unable to manually turn on tv... want to use universal remote.
Purchase a universal remote control and follow the directions for using it.
Jun 13, 2017 | Sharp 32L-X2000 32" TV
TV Turns Off
You may also have a capacitor that is going bad or is on the verge of going poof. Anyhow, check for any leakage on the PCB and if you have a capacitor checker check all the caps. Visual inspection may find it as well...Good luck technician. GURU JAY
Feb 18, 2008 | Televison & Video
Sharp 32l
hi hope u didnt touch enything in there 30,000V is what you get.... after 3 days it will dissolves anyway you can replace it but you'll need your solder experience in hand you need to buy a new unit a good soldering iron and make them small round and neat good luck
Mar 27, 2006 | Sharp 32L-S400 32" TV
Sharp 32L-S400 32" TV Logo
238 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
