Question about HP D2835 17 in. CRT Monitor
On the monitor, only one straight horizontal line display on screen. How to fix it?
How to fix the horizontal line problem on the monitor.
    Master:
  • 788 Answers
Sounds like it's not scanning vertically, probably not worth the money to have a monitor fixed. Time to get an LCD. :-)
Posted on Jan 11, 2008
How to fix white horizontal lines on middle of screen of a PC monitor?
Need to check removing LCD ribbon cable in the monitor. but it is may be a damage of LCD screen ,need to replace the lcd.but in very first check and service the lcd.
Feb 22, 2016 | Samsung Syncmaster S20b300b - Led Monitor...
Thin black horizontal lines across bottom of screen
Hi there.
I suggest you see my tip on how to fix the lines on your monitor. The fix for horizontal lines is the same for vertical lines. You can read my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Slasher_X
Jul 20, 2011 | HP w17e Monitor
When i switch on my system, my Crt monitor is showing horizontal lines(not perfectly horizontal). It seems that the original display is breaking down into strips of horizontal lines. I googled the problem...
I would suggest getting a new monitor as trying to fix a problem with circuitry will often create more, leave it to the professionals. Are you sure it's the monitor? it could very well be the graphics, Buy a new monitor(or use a friends) to test your computer's graphics card. If the lines appear again then you need a new graphics card. If the lines are not there its time to buy a new monitor
Jun 20, 2010 | Computers & Internet
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 27, 2010 | ViewSonic VX2235WM Monitor
Monitor has many horizontal lines flashing across the screen
Yes your monitor can be fixed by an electronical expert! Is not so big problem but you can do nothing without an expert! The fixing-cost is not much! Is just sync problem! If this help you, rate me! Thx.
Apr 25, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
AOC 53N PROBLEM
DO YOU KNOW HOW TO SOLDER. IF SO, TRY TO OPEN THE MONITR AND LOCATE THE VERTICAL SECTION AND YOU WILL FIND LOOSE SOLDERS. A SINGLE HORIZONTAL LINE MEANS THAT THERE IS A PROBLEM WITH THE VERTICAL LINEARITY OF YOUR MONITOR. FIND SOMEONE WHO KNOWS HOW TO FIX COLD SOLDERS
Aug 06, 2008 | AOC 5 En 15" CRT Monitor
Brown horizontal lines sporadically appearing on monitor
I had the same problem. I fixed it completely today. The horizontal lines disappeared. IT IS DEFINETLY THE DEVICE DRIVER. I confirmed my monitor model tyope (dell M783s) and downloaded the specific driver for this monitor.
I had to do these exact steps or did not work.
1) with the problem screen, disabled the display adapter under the Hardware/Device Manager settings.
2) Restart the PC
3) Boot will come up with brown lines still but the screen will low resolution of 600x800.
4) Then I installed the correct device display monitor driver onto the pc. ( you may need to scan for new hardware, then choose the directory with the new hard drive.)
If you need step by step... just reply back.
Dec 02, 2007 | Dell M781S Monitor
White intermittant horizontal lines
Sure it can be fixed, I think some components on the main board needs resolder on their soldered joints. Try this first before thinkig of getting a new one.
Nov 30, 2007 | Videoseven W17PS 17" LCD Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
HP D2835 17 in. CRT Monitor Logo
194 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
