Question about LG RUMOR Cellular Phone
How change the directories from lg for blackberry
How can install hebrew in 8350i
Simple
1. Download and install the multilingual version of "BlackBerry Desktop Manager 4.7" (use a search engine to find it) [Don't navigate using the AT&T page or you will only get the 4.6 option which will not include what you need]
2. Connect your device
3. Click on "Application Loader"
4. Under "Update Software" click on the "Start" menu
5. In the "Device software options" section, click on the "Options" button
6. Scroll to the "Language and Input Support" section
7. Check Hebrew (you may also want to include other options, such as BlackBerry Maps)
8. Click on the "Next" button then "Finish"
Advanced
The AT&T firmware does not include the Hebrew language support. For those brave enough to follow the steps below, and who don't mind to spend the time downloading/installing all the necessary parts, here it is (its really for advanced users only):
1. Search for the Blackberry Bold 9000 download page from a European carrier (I've only tried Orange UK). E.g. search "Blackberry Orange UK downloads".
2. Select to download the BlackBerry Handheld Software v4.6.X.*** (Multilanguage); where *** is the latest version.
3. Install the software on your machine
4. Open C:\Program Files\Common Files\Research In Motion\Shared\Loader Files
5. Open the 9000-v4.6.0.162_P4.0.0.155 (or similarly named) directory
6. Open the Java directory
7. Copy all files ending with __he.cod as well as the net_rim_font_semitic.cod file,
e.g. c:\Hebrew9000
8. Search for "Blackberry Software for Developers" to get to the RIM page.
9. Download the latest Blackberry Development Environment package
10. Install the development environment package
11. Create a new file in the directory where you copied the .cod files (e.g. c:\Hebrew9000) called InstallHebrew.bat.txt and add the following line (make sure its all is on the same line):
"C:\Program Files\Research In Motion\BlackBerry JDE 4.5.0\bin\JavaLoader.exe" -u load *.cod
12. Rename the file from InstallHebrew.bat.txt to InstallHebrew.bat
13. Connect your Blackberry and open the Desktop Manager
14. Double click to run it or open a command line shell.
15. You should see something like:
RIM Wireless Handheld Java Loader
Copyright 2001-2007 Research In Motion Limited
Connecting to device...
Connected
Loading net_rim_bb_crypto_resource__heDone
Loading net_rim_bb_diagnostic_resource__heDone
Loading net_rim_bb_elt_resource_he Done
Loading net_rim_bb_help_umts_wlan__he Done
Loading net_rim_bb_lbs_resource_he Done
Loading net_rim_bb_ldap_resource__he Done
Loading net_rim_bb_passwordkeeper_resource__heDone
Loading net_rim_bb_qm_peer_resource_heDone
Loading net_rim_bb_resource__he Done
Loading net_rim_bbapi_pim_res__he Done
Loading net_rim_bis_client__he Done
Loading net_rim_crypto_resource__he Done
Loading net_rim_font_semitic Done
Loading net_rim_platform_im_resource__heDone
Loading net_rim_platform_resource__he Done
Loading net_rim_platformapps_resource__heDone
Loading net_rim_runtime_resource__he Done
Loading net_rim_secureemail_resource__heDone
Loading net_rim_vad_resource__he Done
Loading net_rim_wlan_bb_resource__he Done
Loading net_rim_wlan_runtime_resource__heDone
502958 bytes sent at ~670610 bps
Disconnected
Note:
- Your device will restart
- You can uninstall the device software and development environment from your computer since you only needed them to obtain the files.
Jan 09, 2013 | Blackberry Curve 8350i
Jvm 102 my blackberry 8900
Here is a temporary solution if you don't want to return your defective BlackBerry and loose all your informations:
JVM 102 error means that a .cod file on your BlackBerry seems to be corrupt. By doing the following steps, you will have a chance to backup your BlackBerry and re-install the OS.
1. Download and install JL_Cmder. You can find it on the web by Google it, or you can go to this web page: http://www.blackberryfreaks.com/JL_Cmder.html
2. Connect your BlackBerry to your PC.
3. Start JL_Cmder and select the option 2 (Event log).
4. Scroll down to the bottom of the log and look for "JVM Error 102." The line before it, should tell you exactly what file is causing the error. Save the file name; you will need it later.
5. Go to Start / Run, and type "CMD" and press Enter.
6. Change directory to the JL_Cmder installation folder.e.g., type: cd "C:\Program Files\JL_Cmder\" and press enter.
7. Type the following command to remove the corrupted file:javaloader.exe -u erase -f FILENAME where FILENAME is the name of the corrupted .cod file.
8. Disconnect your BlackBerry from your PC and restart it.
9. Now you should be able to start BlackBerry Desktop Manager and take a backup of your device. (Optional).
10. Reactive your BlackBerry
11. Restore your backup from BlackBerry Desktop Manager. (Optional).
Regards,
BES Tech
Sep 11, 2010 | RIM BlackBerry 8700g Smartphone
I would like to copy my phone directory onto a sim
Are you a Verizon customer - use 'my backup assistant' to copy the directory to the www. Not a Verizon customer ... you will need to find a cable to conect to your computer and software ...
Jul 27, 2010 | LG Cell Phones
I get error 200 on my bb 8520 how can i fix it
This error code is usually caused by a 3rd party application being downloaded on the phone. Below are the directions that may solve your problem.
What you will need:
A Windows PC (Only tested with Windows XP so Unix and Mac users may need other methods)
Javaloader (Get it Here: http://blackberryforums.pinstack.com...7&d=1149738115)
BB Device (this is your actual device)
USB cable to connect to computer
How do I save myself some time:
Download and extract the Javaloader program to a folder of your choosing but remember it for the next steps.
In Windows XP click Start -> Run -> Type CMD and click OK
change your directory to the drive and directory you saved the javaloader program to
(to change drive type x: where x is the drive letter, to change directory type cd\<directoryname>\<subdirectoryname> etc)
Type "javaloader -usb dir >dir.txt" without the quotes (this will generate a list of all programs on your device into a file called dir.txt in the same directory as Javaloader)
Go to the directory with javaloader.exe in Windows Explorer and open the dir.txt file.
The file has a list of a bunch of module names and versions, etc. This is where I can't give you the specific answer to your problem but can provide some guidance.
I only recommend trying to delete 3rd Party applications so look through the list for module names that look like third party apps. You can also sometimes tell 3rd party apps by the version number as well but don't use this as the bible because some RIM apps are not the version of the OS. Once you find some apps you want to try to delete to fix the problem follow the steps below. I recommend you do this one at a time and reset (if the device doesn't automatically reset) between each erase function to narrow down the issue.
Once you find the module to delete go back to the CMD window and type the following:
"javaLoader.exe -usb erase -f <badmodule_name>" where <badmodule_name> is the module you identified to delete which must be typed exactly as it appears in the dir.txt file.
Keep repeating until it reboots successfully.
If this fails you'll need to - or have a repair facility - wipe and reload your phone's operating system
Apr 07, 2010 | RIM BlackBerry Curve 8520 Smartphone
NOT ABLE TO BOOT 8520 SHOWING ERROR 200
What you will need:
Javaloader (Get it Here: http://www.enduserguides.com/mobile/blackberry/eug_bbjavaloader.html
If this fails you'll need to - or have a repair facility - wipe and reload your phone's operating system.
Apr 06, 2010 | RIM BlackBerry Curve 8520 Smartphone
Hey. i want to get a blackberry curve and i want to take out my sim card in my LG rumor. i do live in canada and my phone is on bell. if it has a sim card where is it and how do i take it out.. oh and last...
Yes you will just have to pay full price for the curve. The sim card slot on the lg Rumor is right behind the battery door which is also the battery. On the blackberry curve you will take the battery cover off then battery then you will see two slots to place a memory card and sim the rest is self explanatory...
Dec 09, 2009 | LG RUMOR Cellular Phone
How to install an application for my blacberry cellphone
If you would liketoinstall application using the application loader tool in the Blackberry Desktop Manager.
You should verify that the application to be installed on the BlackBerry smartphone is saved to the computer before completing the following steps.
If you are using BlackBerry Desktop Manager version 4.5 to 5.0 then you need to follow this steps:
  1. Connect the BlackBerry smartphone to the computer.
  2. In BlackBerry Desktop Manager, click Application Loader.
  3. Click Start where it says Add / Remove Applications.
  4. Type your password, if prompted, and click OK.
  5. In the Device Application Selection screen, click Browse. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Device Application Selection list, verify it is selected, and click Next.
  7. On the Completing the Application Loader screen, verify the software to install is listed under Applications to be Installed or Updated, and click Finish.
If you are using BlackBerry Desktop Manager version 4.0 to 4.3then you need to follow this steps:
  2. In BlackBerry Desktop Manager, open the application loader tool.
  3. In the Application Loader Wizard, click Next.
  4. Type your password, if prompted, and click Next.
  5. In the Handheld Application Selection screen, click Add. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Handheld Application Selection list, verify it is selected, and click Next.
  8. Once the application is installed on the BlackBerry smartphone, click Close in the Application Loader Wizard.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
My blackberry curve freezes on reset with the
Complete one of the following, depending on the network on which the BlackBerry smartphone is operating.
  1. Click the Browser icon.
  2. Expand the Browser Channels folder.
  3. Highlight a third-party browser push channel.
  4. Display the menu and click Delete Channel.
  5. Repeat steps 7 and 8 for each third-party browser push channel.
  6. Complete one of the following, depending on the network on which the BlackBerry smartphone is operating:
If its not working then you need to Re-install the Software
Oct 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
LG RD 2690 UNLOOKING
THE SOFTWARE OR OPERATING SYSTEM OF MY LG-RD2690 HAS EXPUNGED.HOW CAN I INSTALL THE SOFTWARE OR OPERATING SYSTEM IN MY LG-RD2690?
Jun 11, 2008 | RIM BlackBerry Pearl 8100
LG RUMOR Cellular Phone Logo
15 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
