Question about Mitsubishi WS-55905 55" Rear Projection Television
Mitsubishi WS-55905 No picture or sound, but TV stays powered on
I got a WS-55905 for free after the previous owner said the set had problems with horizontal lines. Once I got it home all I can get it to do is turn on. I read that someone suggested that the power supply might be the problem, but the tv powers on just fine. Would part of the board need a repair and it still power on?
  • 5 more comments
  • Tom Fillmore
    Tom Fillmore Nov 19, 2009
    On newer Mitsubishi models the tv won't be able to stay on if the IC's are bad. You can turn it on but 2 seconds after the screen comes on it turns off. The previous owner said there were horizontal lines going across the screen and he couldn't figure out what the problem was. Have you ever had that problem, because I believe my issue stems from that. I will try replacing the IC's, Thanks again for your help.
    PS> On the Sony KP-65XBR10W remote where is the channel button?
  • Tom Fillmore
    I was refering to other tv's I have repaired in my 2nd sentence above. This tv (ws-55905) has no video or audio. I think I can change inputs, but I have no way to tell if it actually does.
  • Tom Fillmore
    Tom Fillmore Nov 22, 2009
    The IC's were fine. I took them out and put the board back in and the set does the same thing. I have no video or sound anyone else?
  • Tom Fillmore
    I have the same problem as before. Your advice did not solve anything. My rating is strictly related to the problem being solved.
  • Tom Fillmore
    Tom Fillmore Nov 23, 2009
    When someone wants my help/advice I gladly give it because I figure the more solutions that are listed on here and throughout the internet, the less questions will need to be asked. Your answer did not fix my problem, if you'd like to try again, give it a shot. I post my questions and read old posts because there is a wealth of kowledge that I like to use to gain some of my own. I've been doing this for about a year and have learned a lot, but obviously need help.
  • Tom Fillmore
    Tom Fillmore Nov 26, 2009
    I put in 2 new stk392-040 IC's and found a broken lead on the 3rd pin in the middle 15 pin connector on the right side of the Convergence board. I still don't get a solid high voltage whine, but it does beep every 3 seconds or so.
  • Tom Fillmore
    All of the green pico fuses are fine. What is the location number for the HOT?
  • Mitsubishi Master
  • 5,138 Answers
Most of the time its the STK ICs they are big Black ICs they will have Part number on them example STK392-570 replace both of them Call Mats for parts and you will need heat sink silicon as well to put on back of ICs 1-800-628-1118
Posted on Nov 19, 2009
  • 3 more comments
  • ladywinn
    ladywinn Nov 19, 2009
    Try going to this website Encompass Parts Distr. they have Parts you need for repair to the WS55905 or you can call But Look to see what all they Have Listed you may just want to try them!
    1-800-638-3328 they also List Parts for the Sony you have .
  • ladywinn
    ladywinn Nov 22, 2009
    If you have 2 Different TVs then Post them separately
  • ladywinn
    ladywinn Nov 23, 2009
    When a customer brings in his TV to My Shop there is a $125.00 CK out Fee and they Gladly Pay it!
    Labor Rates Start at $190.00 and if customer has set Repaired then we subtract $125.00 from repair Bill.
  • ladywinn
    ladywinn Nov 24, 2009
    Did you replace ICs with new ones or just reinstalled the old ones?
    these 2 STKs One controls Power start up and the other controls convergence And is the hori output Transistor OK? also look for Bad Capacitors there is one that feeds the hori output if it is Bad set will alo shut off and Have you checked All of the pico fuses they look like resistors but are fuses they will be yellow or green 5amp 6amp 7amps?
  • ladywinn
    Try www. Repairworld.com
Mitsubishi ws-48315
Its a V24 chassis---it will blank or turn the picture tubes off for a number of reasons--all self protection. Someone would have to look---I presume when you say no picture you mean no light of any kind on the screen.
If no raster (no light of any kind on the screen) problem could be in Vertical or Horizontal sweep circuits which covers quite a few possible parts.
If the set had for example a blue screen only or is stuck on one input there is always to possible hard reset but that will not cure no raster.
SD TECH
Apr 27, 2012 | Mitsubishi WS-55905 55" Rear Projection...
Green edge appears around images
Tv have a problems known as the convergence problems,it dead.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Aug 11, 2010 | Mitsubishi WS-55905 55" Rear Projection...
The picture on tv looks dimmed on my mitsubishi WS-55905
There are a few things to try first if you have not done so:
If the set has not been "serviced" for several years, unplug it and remove the back cover. You will see 3 large black lens dead center above the main boards-------wipe them clean either with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
If the lens are dusty, the picture will be darker and duller looking than it used to be.
Let me know what you find as I am here to help.
SD TECH
Jul 30, 2010 | Mitsubishi WS-55905 55" Rear Projection...
Green edge around images (outline)
my 2002 sony wide screen projection tv has menu and pictures when turned on first thing in the morning?
Jan 30, 2010 | Mitsubishi WS-55905 55" Rear Projection...
No picture or sound
This would start with the power supply on up to the conv. board.. I have seen som many TV's like this wiht problems.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Mitsu model #ws-55905 Started losing picture while watching a DVD. The next day it worked fine. Now it lost the picture and sound completly. I have no response at power on, only the green power indicator....
actually something on the main board was getting overheated before due to that it was loosing the picture.and now that component is got totally overheated and blowned/burned out.so its quite necessary to replace that faulty component from the board by checking it with a meter.so its advisable that you do not turn on your tv to avoid further damages till it gets repaired.
Feb 20, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Mitsubishi WS-48613
Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
Nov 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-55905 55" Rear Projection Television Logo
300 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
