Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Recently when powered up, sometimes the sound
Recently, when powered up, sometimes the sound would not come on and then when powered again it would. Now I haved no sound at all. Something went bad over two or thre days ime. What is the problem?
  • stevemckelve Nov 19, 2009
    I do get sound from the line out RCA jacks.
    ...Steve.
  • 11,361 Answers
Let verify first to narrow down to where the problem can be. First, attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Posted on Nov 19, 2009
Testimonial: "The information was verry help, just not what I wanted to hear. I was hoping they might have sub-component levels to change out.Thanks for your help."
  • Bud Martin
    Bud Martin Nov 19, 2009
    If it sounds normal through the RCA audio output, then you have problem in the power amp section, for most TV, you will need to replace the whole main board! unless you will want to pay a lot of money to troubleshoot down to component level. You may be better off using the RCA out and just turn off the internal speakers in the onscrenn audio setup. You also may be able to set the RCA out to be 'VARIABLE' instead of 'FIXED', this will aloow you to use the TV volume control to set the output level.
I have my Desk top and Monitor frome Dell Recently I have this problem with the Monitor where each time I Open my Computer it goes for few seconds then blak, but if I switch monitor off then on again...
Sounds like a bad power inverter. You can easily purchase the part online and fix it yourself. Ebay sells plenty of them from prices ranging $15.00 and up.
Sep 20, 2010 | Dell Computers & Internet
Can't power on TV occasionally
It is possible that the conductivity of a power diode is diminished after a period of time causing the unit to receive just under the needed current to function. Test the resistance of internal components after periods of tine or seek manufactures assistance.
Apr 12, 2010 | Samsung LN52A650A LCD TV
My Samsung HLP4663WX has no picture, can't power off
it may be a bad DMD board. This is usually the problem when you get the three lights of death.
Sep 17, 2009 | Samsung Televison & Video
Power windows will stop working sometimes up sometimes down. happens when turn car on or when driving. have had to turn off and restart as well as open and close door and retart multiple times to get to...
Sounds like you have some wiring issues. Did you recently install any new hardware into your car? If so, I would check all the wiring to make sure it is correct and that you are not shorting anything out. Also check all the fuses to make sure none are blown or need replacing.
Aug 21, 2009 | 1997 Jeep Grand Cherokee
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
Sometimes when i start my car there is no sound. all of the options (radio, cd, dvd) seem to be working and i can switch between them, however there is no sound. i have to turn off the car and let it sit...
sometimes when i start my car there is no sound. all of the options (radio, cd, dvd) seem to be working and i can switch between them, however there is no sound. i have to turn off the car and let it sit for a few min. once that is done, i get sound again. is there a reboot option while the system is powered? and what else is there to check?
Jul 10, 2009 | Eclipse AVN5495 Car DVD Player
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Powers off after 15 seconds to 1 minute
solder issue at the flyback. try resoldering the flyback
May 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
235 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
