Question about Car Audio & Video
What do I need to do to get my cd player to work again?
My cd player will not work . There was no problem and then one day it wouldn't accept the cd and stopped playing. The radio still works beautifully and the speaker system is perfect. I have 158,000 miles on my beloved Accord!
  • 364 Answers
CD players are notorios for missalignment of the laser, to fix them is quite costly and cheaper to replace the unit is usually the option. You can however buy a cleaner cd to run in the unit, ask a supplier where to get one. Good luck
Posted on Nov 19, 2009
Testimonial: "Replacement is what I was afraid of but if it's to be it shall be! Thank you for your advice!"
Fix my cd player in my vw polo
Usually you can nor repair these. I know some CD player back in the day will not accept cd rw. If this is not the case may be time to replace it I mean it is almost 10 yrs old.
Nov 27, 2012 | 2004 Volkswagen Passat
Sony DVD not responding to power
open the top cover and chech the fuse in the power supply board,if ok then check on the diodes and probably the ic for power
Dec 15, 2011 | Sony Televison & Video
Problem for Blaupunkt Bermuda MP36 Car CD Player. I was getting the error CD error when I use to insert the mp3 cd in the CD player. I complained and was asked to reset it by disconnecting the battery...
It is possible that if your normal standard recording are working fine, then the format of the MP3 is not recognised. If so please try and rerecord on the acceptted format. If this MP3 was playing earlier to the fault then it is a possible failure of the processing section. If your cd is not reading but ejecting out then it is a fault in the optical for a possible weakening of the the laser. If you have warranty claim for this failure. however if it is readding but there is no output please check as above with a standard mp3 format. Howeverr if there is sttill no result I beileve you will have to get the main board replaced. If you are familiar with electronics you have to check within for the RF and signal to confirm for the suspected stage. however attempt only if familiar. Hope you follow this guidance. Good day
Jul 13, 2010 | Blaupunkt Bermuda MP36 Car CD Player
Cd player doesn't play mp3 files recorded on cd
Possible that the format you have recorded is not accepted by the player's specification. I would recommend that you re-reccord the files with MP3 compression that is accepted. Use another software - nero- should be fine. If this wont work but your audio files play Ok then it could be a fault within the audio processing section. Hope your get this right. Good day
Jul 06, 2010 | Blaupunkt Brisbane SD48 Car CD/ MP3 Player
2005 Dodge Durango RDS radio
I HAD AN AN MVA IN 1/2009 (REAR ENDED ANOTHER VEHICLE) MY RADIO/CD PLAYER WORKED PRIOR/AND IMMEDIATELY AFTER ACCIDENT. THE NEXT DAY MY TRUCK WOULDN’T START, BATTERY WAS COMPLETELY DEAD. I RETRIEVED MY TRUCK 3/2009 ….. MY RADIO WILL PLAY, HOWEVER, I AM UNABLE TO CHANGE MODE FROM TUNER TO CD PLAYER, CD PLAYER JUST MAKES A NOISE AS IF ITS CHANGING DISK, THIS SOUND CAN BE HEARD WHEN I UNLOCK MY DOORS WITH OUT IGNITION ON; .....ANY SOLUTIONS OR ADVICES IS WELCOME
Jun 30, 2009 | 2005 Dodge Durango
Car cd player won't read or accept cds
My chevrolet will not accept the cd...when inserted it immediately ejects...ERR and Radio flash off and on...help
Jul 27, 2008 | 2000 Chevrolet Silverado
Dual xdvd8181
i have a dual xdvd8181 cd player and the radio works fine but it will not accept a cd. what do i need to do about solving the problem?
Jul 22, 2008 | Car Audio & Video
Xtreme sound wms303 cd player..... need a new one?
It sounds like if it only works a day or two and then you disconnect it and re-connect it, and it works again for a day or two, I don't think the problem is how you are connecting it. I think the radio needs to be reset every couple of days. If it has a reset button, just press that and it will at least keep you from disconnecting it and reconnecting it.
This also sounds like it has an internal electronic problem. When you disconnect the radio, it resets the microprocessor. You should have it checked out by a service center, or if you do not want to spend any money on this radio, just get a new one.
Jul 06, 2008 | Xtreme Sound WMS303 CD Player
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
200 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
