I had a convergence problem in my rca projection tv but i put in a new convergence and it did not solve the problem ....what now?what else could it be?
  • deannahuffma Nov 19, 2009
    okay i did not have to solder any thing i have another tv exactly the same the other tv has a power prob so i took the whole board that has the convergence on it and swapped them out and the convergence on that one is good but not workin for the other tv...any thoughts?
    so what exactly am i lookin for on the convergence one if those pins are bad how can i tell?
  • 273 Answers
Look at your source voltages that may be missing
id look at pin 11 and 12 on the flyback transformer and check the source fuse after resoldering those connections
Posted on Nov 19, 2009
  • T.l. Moore
    T.l. Moore Nov 19, 2009
    on the smps power supply deflection bd on the tranaformer look at pin 11 and 12 and check your source fuse
  • T.l. Moore
    there likley will be ring cracks around the pins that solder through the board and it is on the deflection board no convergence board
    and i assume were talking about a d52w20 or a model like that
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
My RCA HD52W59 HDTV Television has double vision and red, green and blue colors separated like a spectrum in stead of all the colors blending together to make one uniform picture. What can I do?
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 09, 2010 | RCA HD52W59 HDTV Projection Television
I have a RCA Rear projection TV and the picture on it looks like a bow tie
This problems u have is known as Convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-$350 for parts and labors.
Aug 16, 2010 | RCA P52929 52" Rear Projection Television
3 D picture. Double letters, etc
Tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Aug 06, 2010 | RCA HD52W66 Projection Television
Out of focus. looks 3-d
This tv have a problems known as a Convergence problems,it dead.The tv convergence board must be require change the 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-3350 for parts and labors.
Jul 04, 2010 | RCA HD61W66 61" Projection HDTV
Got and RCA Scenium CRT HDTV (D52W135D) which seems to have a convergence problem, green shadow over picture. DVD picture is very dim also
This tv have 2 problems than,the tv projection lamp life is over,that why the picture is dim,must be to replaced with a new picture lamp.The tv convergence board the 2 STK convergence ICS and some or all the resistors are dead.Replaced all these parts to solved the convergence problems.
Jun 24, 2010 | RCA D52W135D 52 in. TV/DVD Combo
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
