Question about Sony Grand WEGA KDP-65XBR2 65" Rear Projection Television
Display yellow with a round spot in the center of screen i think it might be the lamp any info on how to find if it might be something eles
    Genius:
  • 1,112 Answers
Hello: This unit does not have a lamp. It is a CRT read projection version television, Your symptom indicates to me that the RED CRT is defective. Replacing it would restore the television back to normal.
Posted on Nov 19, 2009
TOSHIBA 57LX177 SHADOW SPOT CENTER OF SCREEN
If my research is correct you recently replaced the lamp and then the "shadow spot center of screen" appeared.
Three possible reasons I can think of for this:
Something wrong with new lamp or on face of lamp--never touch the face of a lamp as oil from you hand can leave a residue and damage the lamp or cause a image issue.
Something inside on the optical lens or even the mirror causing this--not likely but possible.
A defect in the optical light engine in the set---usually if heat which comes from the lamp damages the engine it will be a color and not black---engine has a series of lens and baffles inside that heat can damage--causes minute separation inside of the lens etc.
If the old lamp works at all try putting it back to see if same issue--did you replace just the "bulb" in the housing or the whole cartridge?
If remove new lamp look at it and where it faces--usually a clear lens faces it and if some dirt on that..........
Jun 03, 2012 | Televison & Video
My View sonic LCD Projector has a large Yellow discolored spot in the middle of the screen when using it with my computer. Our AV person changed the bulb thinking that was the problem and then the whole...
not sure which model you have but sounds like the blue polarizer has overheated over time. when you put the new lamp in I would think that the extra light you now have is highlighting the problem more plainly.
If this is the case then a new polarizer would be needed
Mar 01, 2011 | ViewSonic Office Equipment & Supplies
Hitachi 55vs69a yellow blob in center
you most likely have a bad light engine.
Aug 20, 2009 | Televison & Video
Green spot in middle of image as though a spot light was shinning on the screen. I've replaced the lamp
Welcome to LCD 101, the blue device is dying in the projector. Replace product with dlp brand and it will last a lifetime. good luck
Apr 14, 2009 | Epson PowerLite® 1700c LCD Projector
Sony 60" LCD projection TV has yellow screen discoloration
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
Feb 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
InFocus LP 850 Projector, yellow spot on screen
Unfortunately the discoloration is caused by the extreme heat generated by the Lamp has burned the LCD optical polarization filter/elements.
The only solution for this is to replace the entire LCD optical assembly.
Sorry for the bad news, :(
Jan 29, 2009 | InFocus LP 850 Multimedia Projector
Have yellow spot in center of screeen
it is actually a light engine problem, i have replaced probabily 50 of thease for that exact problem, it is a prity hard part to change yourself, and it costs about 400 dollars
Jan 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Yellow Spot dead center on screen
Any color spot is never the lamp with this type of set.
the yellow spot is caused by the optic block (Engine). Very expensive to buy.
Little over $1000 plus labour with a qualified technician.
Sometimes technician may try to clean or repair inside but most likely won't succed.
good luck.
Sep 20, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Yellow spots are appearing in the upper right quadrant of the screen. After the set has been on for a couple of hours a second spot appears in nearly the dead center of the screen. This issue coincides...
Try the new lamp as indicated by the blink codes. That may resolve the problem. If not, the problem is in the "light engine" portion of the set which should be covered under warranty.
Keep us posted.
Dan
May 29, 2008 | Panasonic PT-52LCX65 44" HDTV
Yellow spot in center of screen
I have recently developed the same yellow spot problem on my Sony KDF-E50A10  50" LCD television...a large yellow circular hue that takes up the bottom center of the picture and is especially noticeable against a white background.  It has been diagnosed as the optical block (light engine) and without an extended warranty Sony refuses to assist with the repair cost.  Repair was estimated at $1,100 plus tax and travel fees to my home.  So you see, it is not only a Hitachi problem.  You would think they could build something that would last more than two years considering the initial cost of over two grand for the TV !
Jan 03, 2008 | Hitachi 50V710 50" Rear Projection...
Open Questions:
Sony Grand WEGA KDP-65XBR2 65" Rear Projection Television Logo
175 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
