Question about Maytag Performa PAV2200
No hot air in drum - Maytag Performa PAV2200
  • 111 Answers
The heating element has gone south, its a problem that is probably better left to a pro as the dryer must be almost completely dissassembled to change it. sorry its not an easy fix.
Posted on Nov 19, 2009
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Dryer getting hot but not blowing hot air out
Unplug and stop using sounds like a fire hazard, try cleaning out the lint filter and replacing the exhaust hose, and make sure your homeowner policy is paid, hope this helps,
Nov 05, 2013 | Indesit Dryers
My dryer run all day and night if I would let it.And it takes one day to dry my clothes what is wrong with it
If it gets hot or warm in the drum but the clothes do not dry---the most common cause is a blockage between the drum, lint tube in the unit to the vent that flows the air to the exhaust outside.
If the drum gets much hotter than the air exiting the vent----clean all the from the drum to OUTSIDE.
Note: if there is not proper airflow and a lint build up exists there is the potential for a fire---Hundreds of fires are reported each year cause by this kind of trouble.
If the drum does not get hot inside you may have a bad igniter that heats the air (fires the burner uo inside the unit.)
Dec 07, 2012 | Roper RGX4634KQ Gas Dryer
Dryer not drying clothes
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
Aug 20, 2011 | Dryers
Can 3431 be converted to a regular vented dryer?
You cannot convert this model. This unit blows hot air into drum and the water is turned to steam and exhausted out through the pump to the drain. Unlike regular dryers that blow hot air into drum, creating link and just heat that blow out vent.
Jun 22, 2010 | LG WM3431 Front Load Washer / Dryer
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
The dryer does not seem to push hot air into the drum. The heating element works in that I can feel it being hot, but there does not seem to be much, in any, hot air being pushed into the drum.
Make sure that the vent is not blocked. Also check that the fan is not broken (reasonably common). The fan is bottom right once you remove the front panel.
Dec 11, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
Dryer will not produce hot air. What could be the problem? I opened the back panel and there is a square shaped box that was hot. Is that the heat element?
The heating element should be nearly the diameter of the drum and is generally round. If the box of which you speak is about 4 to 6 inches square, it is probably an electrical connection box and shouldn't be getting hot. If this box has a removable cover, unplug the power cord and remove the cover--look for loose connections. If all ok, replace cover. Does the drum turn? Start the dryer and check for air blowing from the outside vent. If not, check for plugged lint filter (wash with hot water and detergent) and lint plugging the flex-hose between the dryer outlet and the outside vent. After running for a little while, feel the back of the drum to see if is generally hot--if so, then the heating element appears to be working. Hope this helps.
Jul 26, 2009 | Dryers
Dryer working but not blowing hot air
it sound like the heating element. look to see if it is broken
May 08, 2009 | Bosch Dryers
Tricity Bendix WDR1240W Condenser dryer problem
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Nov 01, 2007 | Tricity Bendix WDR1240W Front Load Washer...
Washing Machines Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
