Question about Intel Motherboard
My cpu green led is glowing but monitor screen is black and keyboard led is continue glowing
  • 115 Answers
There are No display in your system .Pls remove Power cable from CPU and again plug it and start your system.If display still not comes then pls remove RAM chip from slot in the Motherboard and re-install goods one and check it.if still display not come then issue with Motherboard .Its detter call vendor for repair the Motherboard.
Posted on Nov 19, 2009
Monitor keeps shuting down
what do you mean by "computer starts"????? plz write full detail. first remove your monitor cable from your cpu cabinet. if you are able to see "no signal" message on screen then your monitor is working. if you aren't seeing anything on your screen then there is some problem with your monitor. there also may be problem with your VGA connection (VGA or D-Sub wire). remove and reconnect this wire from both end. first reconnect it from your monitor and then from your video card. if it dosen't fix then you have to check that all led's are glowing on your cpu cabinet or not. if only power led is glowing and other led's always remains off, then there may be problem with your video card or ram or hdd. first open your pc case, then if you have video card, then remove it and put it again. reconnect your hdd sata wire. remove your ram and place it again. if now also not showing anything on your screen, then there is problem with your motherboard bios.
Apr 10, 2013 | Computers & Internet
My desktop computer after switch on , CPU power led glow and on, monitor is on , drive light are on but no beep sound and screen is black . I replaced the cmos battery, memory card ...
The mother board name would be helpful. The name of the computer also.
A quite a few things can be the problem here.
The mother board could be bad with something wrong on it.
The memory should be checked.
Possible problem or defective CPU can also cause this kind of problem.
Not to be overlooked would be a possible problem with one of the cards.
So... I would recommend (with power off and cord removed from power supply) for you to remove all cards. Try by turning on the computer.
If at this point you get no power as you did at the beginning, then you need to check the CPU by either using another one (if possible) or have a friend try the cpu in another computer. If that does not work, then the problem is more than likely in the mother board. At this point if the motherboard is not good (should be checked by another person or friend) , also do not overlook the power supply.
Next... Remove all drive connections such as cdrom, hard drives and floppy. Turn on the computer and see if you can get the bios to come up...if it does, set the bios to default settings.
Next put each drive in one by one and then turn on the computer after each one is connected. If you are still able to start the computer, then put in the cards one by one and try the computer again after each one is put in the slot it came from. This is the process of elimination to see which part is at fault.
Sep 01, 2009 | Computers & Internet
No image on monitor
Looks like the Video card, or Video chip has bought the farm
Try hooking up to another monitor to confirm where the problem is.
Jan 30, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
No power!!!
Dear javier4017,
> First ensure that any beep is coming or not
> check numlock LED status glowing or not.
> If numlock LED glowing it means cpu working fine
only problems with monitor
>If numlock LED not glowing its mean problems with cpu
> if problems with CPU Find check RAM may have dusting problems.
Dec 07, 2007 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
Power Led (Green) Flashing
Inorder to verify that the problem is with the monitor have you tried the monitor with another CPU could you please try it because it might be a problem with it the signal may not be reaching with monitor
Jul 26, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
