Maxtor N256 Jumper settings - Computers & Internet
    President:
  • 2,049 Answers
Here's a link to them on the Seagate site... (Seagate acquired Maxtor)
http://www.seagate.com/staticfiles/images/support/en/us/mxo_ata_jumpers_rev.jpg
Posted on Nov 19, 2009
    President:
  • 2,185 Answers
All Maxtor hard disks has a diagram in them on where you should put your jumper if you need to set it as primary or secodary slave, etc. Just look closely at the label sticker.
ODCaloney
  • 260 Answers
SOURCE: jumper setting for maxtor n256 diamondmax vl 40
There is usually a diagram on the drive showing the jumper configuration.
Posted on Mar 16, 2009
Geekinator
  • 183 Answers
SOURCE: Can not find Jumper diagram on N256 Maxtor model 33073H3
Hello there soggytundra, here's your GEEK-steer ...
Despite your question being posted here 5 days ago, I'll presume you still (and if not, then someone else will) need the answer ...
Virtually all Maxtor drives adhere to the following general rules concerning jumper settings (at least up until now):
= MASTER (M): Insert jumper over the FIRST COMPLETE pair of VERTICAL pins.
Examples:
Xoo o oXooo Xooo
Xoooo Xooo Xooo
= CABE SELECT (CS): Insert jumper over the SECOND COMPLETE pair of VERTICAL pins.
Examples:
oXo o oXooo oXoo
oXooo Xooo oXoo
= SLAVE (S): Do NOT insert ANY jumpers (or at least NONE VERTICALLY, but you may HORIZONTALLY across the TOP row as simply a means of storing the jumper).
Examples:
ooo o ooooo oooo oooXX oooXX ooXX
ooooo oooo oooo ooooo oooo oooo
TIP: As a general rule, if you KNOW the role of the jumper capable device you're installing, it is better to NOT use Cable Select (CS). In this case you do, therefore it would be best to specifically designate the (33073H3) drive as (secondary) Slave [and your other (primary) drive as Master].
Good luck and GOD-speed. Please post back if you have any further questions, and/or just to let me (and others in similar need) know how well this steers to solution.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Apr 02, 2009
jamespcastle
  • 128 Answers
SOURCE: I need the jumper settings for Maxtor N256 hard
Hard drives have three jumper settings on them.
1.MASTER---MA
2.SLAVE---SL
3 CABLE SELECT----CS
If you have a hard drive on the end (last) on the ribbon cable connectors, then it is the master drive, and should be jumpered as such-- the jumper should be on the MA pins, any drive in the middle of the cable is jumpered as slave and should be on the SL pins.
CS usually causes problems, and I do not use it.
There are no jumpers on the motherboard that need to be changed for the hard drive. The only other settings for the hard drive are in the BIOS.
Please vote 4 thumbs up!!,
James.
Posted on Apr 25, 2010
Wins411
  • 166 Answers
SOURCE: Slave jumper settings for a Maxtor N256 Hard Drive
I have never personally seen one but most drives are the same for the type of jumpers installed. See if this helps you:
http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
Posted on Apr 28, 2010
  • 100 Answers
SOURCE: Jumper setting for maxtor n256 diamondmax vl 40
see the settings from the following site pdf.
Posted on Sep 05, 2010
Maxtor hd jumper settings n256 91366u4 primary
MAXTOR: no jumpers --> Master
one jumper --> Slave
two jumpers --> Cable Select
Dec 20, 2010 | Maxtor Hard Drive
Apr 28, 2010 | Maxtor Hard Drive
Jumper settings
25870e5.jpgCheck this diagram. it shows all configuration in detail..
good luck!!
Jan 02, 2010 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Jumper setting for maxtor n256 diamondmax vl 40 5400 rpm
Mar 16, 2009 | Maxtor Hard Drive
Jumper setting
The first jumper goes up and down on the two pins just beside the IDE cable slot and the other jumper goes across the top two pins next to it
Jan 23, 2009 | Maxtor Hard Drive
Maxtor HD
The second pair joined (jumper) I suspect it is configured as cable select.
J50 is the left-most pair, and joining them sets the drive as master.
Apr 04, 2008 | Computers & Internet
Computers & Internet Logo
7,827 people viewed this question
David Payne
David Payne
