Question about Maytag Performa PAV2200
Machine works but does not dry cloth no hot air drum? maytag performa
  • 76 Answers
Chek closely all the tube going from in to out of ur dryer clean all ur filter even the furnace oune! check ur wirring, if all faisl dry nothing in ur machingr for one cycle. they wil { i hpoe
Posted on Nov 19, 2009
Maytag Performa PYE2200AYW drum turns until I put clothes in it, then it slows and stops.
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to
May 29, 2012 | Maytag Dryers
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
I have a maytag performa electric dryer model #pye2300ayw, rev 10 -- sometimes I need to run the dryer 3-4 times to get a load dried. I checked the outside vent and there is alot of hot air coming out, the...
We had this same problem recently. Don't know if your problem is the same, but I am sure it could be.
While we did have hot air coming from the outside vent, it was still a restricted vent duct that was our problem. I went to Lowes and bought a dryer vent cleaning kit for about $40 (I figured I needed to do this anyway, as I'd been hearing about how many housefires are caused by the heat buildup from poorly breathing vent tubes/ducts), and cleaned the whole length of the duct (and replaced the plastic flexi-tube inside with a metal one).
I had thought I had good air-flow before doing this, but oh my gosh, what a difference this made! And I couldn't believe the pile of nasty, damp lint that came out!!
Anyway, our dryer immediately went from requiring 2-3 cycles to dry a load of clothes, to doing a great job the first time through! Perhaps the same solution would help you. I hope so!
May 29, 2010 | Maytag Dryers
My Maytag Performa dryer is taking 2 and sometimes 3 cycles to dry clothes. Suggestions as to why?
Most of the time the dryer blower wheel part number 53-0106 gets loose and and cause this problem. I fixed one just the other day.
Feb 24, 2010 | Maytag Performa PAV2200
Dryer has heat in back but cloths won't dry.
Howdy: Some models have a little fan that blows the hot air into the drum. I do not know what model you have but I would start there. Sorry - Good luck - Doug
Dec 09, 2009 | Maytag Dryers
Dryer drum rotates but no heat to dry the clothes. Happens occassionaly and then dryer seems to work ok.
burnt or loose power supply cord at the point it attaches to your dryer. also may have a clogged vent.
Oct 31, 2009 | Maytag Performa PAV2200
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
Dryer leaving black marks on clothes
contact the factory for replacement patrs.richardm69
Dec 14, 2008 | Maytag Performa PAV2200
Maytag performa pav2300
Just rehook the clear tube back onto the air dome (back right side of drum), drain any water from the drum, the refill, pressure switch will reset itself. Start to fill on small load size first, then move up when washer starts to be sure it reset all the sizes.
Aug 06, 2008 | Maytag Performa PAV2200
Noisy washing machine
Side ways movement is normal, possible dry bearing seal, try running through on hottest wash, this should resolve the problem. Regards Engineer
Jun 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
