Question about HP Pavilion a1120n (PX759AA) PC Desktop
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
  • 50 Answers
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Posted on Nov 19, 2009
  • HP Expert
  • 276 Answers
First check the power supply or swap another.
Clear CMOS jumper or remove the battey
connect only power 20 or 24 connect and test power on. no off? (no video because no power to cpu by 4 pin or 6 pin connector)
plug 4 pin connector and test power on. if on and off check cpu power section (mosfets) if burned one pls remove ... you can test short by touch the mosfet by finger (burning heat)
Posted on Oct 11, 2016
Why is my Sony VAIO VPCEB33FM green power light flashing?
It won't be the cpu. If it was, nothing would happen. I would look for a GPU issue, possible over heat.
Jan 01, 2015 | Sony Vaio Vpceb33fm
Cpu fans starts and ends in 2 seconds
Check that a 4-pin power-cable (2-by-2 layout) from the new power-supply is connected to the matching socket on the motherboard (or maybe to a high-end video card).
Feb 07, 2014 | Cars & Trucks
When i apply power, the cpu fan and power supply fan turn a few times then they stop and restart. This cycle continues for about ten minutes then the OS loads and runs fine. This happens every time I turn...
That means the PSU( power supply unit ) is already malfunctioning. Try to use a spare PSU and try that if that happens again.
Hope that helps you out!
Aug 09, 2011 | Intel DH55TC Motherboard
When i plugged power cable to my pc cpu fan start without press power button
It should start for a few seconds, the fans should spin and then stop. You should be able to power it up as per normal. If that is no the case then you are having hardware issues which could be the Power supply
Apr 03, 2011 | Intel 845GE Motherboard
First of all, I have a Gateway Model FX7026 desktop computer. My daughter was using it when suddenly the monitor screen becomes black. She tried to turn the computer on again but nothings happen. I open...
check if the cpu fan its working fine, maybe is damaged o dirty, you clean up with an air compress can
if still doesnt works you can try to replace the fan and see if it works
Mar 31, 2011 | Gateway FX7026 PC Desktop
HP media center pc ,1170n will not boot. black screen. You can hear the fan come on but black screen.
Sounds like a capacitor has blown on the motherboard, but before condemning it, check the following:
1.) Does the CPU fan turn and does the heatsink get warm after a few minutes?
(This indicates that power is at least getting to the CPU
2.) Check connections of ALL the main power connectors (ie: the 20/24 pin plug to the mainboard and the smaller 4 pin plug to the mainboard.
(If not firmly inserted will stop the board from firing up)
3.) Check the graphics card is firmly seated and test with anew graphics card to eliminate the issue being with the graphics card / check tightness of the VGA cable to monitor and card
4.) Remove all but the main power and 4 pin power plugs and try rebooting to eliminate hard drive or DVD drive failure
5.) Remove and replace each ram module in turn try booting in between
6.) If you have a spare PSU, replace the existing one and test the board using that, sometimes the PSU appears to work, but lacks power to fire up the board.
After all that, you are down to the mobo or CPU, you can try a new CPU, but I feel that the issue is with a blown capacitor or a burned circuit trace, only close inspection of the mobo will reveal bulging, leaking or blown capacitiors (small cylinder like things on the motherboard)
Jan 17, 2011 | Computers & Internet
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
I have an issue with a computer. one day it stopped turning on all of a sudden. checked PSU and its not getting any power. (usually fan will turn a bit then stop), now decided a faulty PSU is the problem...
Good day.
You are down with your motherboard as the main suspect of the problem. To isolate it, remove all the devices (hard disk, optical drive, video card, memory) that is connected to your board. Turn-on your PC. If your PSU is still acting abnormal then your motherboard is defected and you need to buy a new one, else, you can replaced one at a time the devices you have removed earlier.
Feel free to post again here at Fixya if you still have a problem.
Good luck.
Oct 06, 2010 | Computers & Internet
Wont turn on just flashes.wont turn off just flashes...Is there a reset button??All of a sudden it just stopped and started flashing no warning.
First try to turn off PC by holding power button for more than 5 seconds. Make sure first that your PC is clean inside and CPU is properly connected to motherboard (before you touch inside your PC touch some metal to discharge electrostatic). If it needs cleaning use canned air and paintbrush. Check how memory is connected. Check the Power Supply voltage, if it's ok, first turn PC off,then you can check power button by disconnecting ATX 20 or 24 pin power connector from motherboard and connect paperclip edges to any green to black wires it has to power on your PC. If it's still flashes it's more likely PSU or motherboard issue.
Jan 15, 2010 | HP OfficeMax - CPQ SR1638 NX-B Desktop....
PC won't boot (no signal and no beeps)
check the board for blown capacitors. I have found many boards from power circuits to motherboard with popped capacitors over the past 5 or so years. replace them and tada, it lives again. I've been successful several times with this operation. Please see the picture below for a guide to finding bad caps.
Jan 02, 2010 | Intel Motherboard
HP Pavilion a1120n (PX759AA) PC Desktop Logo
333 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
