Question about Saeco Royal Professional Espresso Machine
Saeco Royal Digital won't brew coffee
Hi, our machine has intermittently stopped brewing coffee and grinding. after removing brew unit, cleaning and cooloing down machine,it worked again but today even this has not helped.
Machine grinding beans now but after that there is only hot water being dispensed into cup, with no coffee. The cycle sounds "right" but when you look in the cup there is only hot water there. The machine has said "descale" for past week but I haven't got around to buying anymore descaling solution but will do so, today. Could this be a 'descaling needed" problem or is something else likely to be wrong. The machine is 5 years old almost and has made 8,500 coffees.
  • 1 more comment
  • Oscarlaw
    Oscarlaw Jan 24, 2008
    The machine is still not working and the brew unit looks normal....no blockages or obvious problems.
    No coffee dregs are dispensed to the waste container as the "coffee grind" and water never come into contact.
    The grinder grinds up a portion of beans and that's it. The coffee grind does not leave the part of the machine where it is being ground up.
    The next part of the cycle starts up, dispenses hot water, and this does enter the brew unit but as the coffee grind is not there, it only produces hot water....no coffee!
    We have descaled the machine, totally cleaned out the grinder but the coffee dispensing part of the machine does not seem to be doing it's job.
  • Anonymous Feb 26, 2008
    Having the same problem. And I just had my machine completely overhauled and serviced! The grinder doesn't operate and all I get is water!
  • Anonymous Mar 18, 2014
    have saeco incanto machine and steam has progressively slowed down to an intermittent pressure to a stop. have cleaned (descaled) and has reinstated pressure for a few more coffees then stopped. is it pressure pump and can you buy one yourself and put it in.
  • 2,042 Answers
Normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Posted on Jan 15, 2008
6ya staff
SOURCE:
Machine will not dispense water at all,leaks behind dispenser, doesn't brew coffee
Hi. Great machine. You have a brew unit blockage. Remove the brew unit and clean. It canbe striped down and cleaned, but does requirer a bit of expertise in stripping them. Dazza REPAIRER
Sep 23, 2011 | Saeco Royal Digital Plus Coffee...
Hello, I have a Saeco Royal Digital Plus. I have a problem with water getting into the little tray under the brew. (Normally there will be little coffee residue in the tray). While doing the thin coffee....
This a normal operation. As much fine is the coffee grinding is set then the water make it more difficult to pass through and when the coffee process finish the water remains in the piping sytem after pressure lelease in the try under brew group. All you need to take care is that the grinding is not adjusted too fine thus runnig very slow and coffee will be burned and become bitter. Also you need to remove the brew group very often and clean it with warm water and every month remove the st. steel filter from brew and clean it so all holes are open from dry coffee. You can also use the special coffee cleaning tablets to perform a cleaning proccess so the machine remains in good shape. You can find all these informations, parts and others about your machine at the http://www.partsguru.com/SaecoRoyalDigital.html
Jul 17, 2011 | Saeco Royal Digital Plus Coffee...
I have a Royal digital machine it will grind coffee for an extended period then stops and displays out of beans.Although there are still beans in the hoper, pull the brew draw out and the ground coffee...
Try this first. Empty the brew unit of any coffee. Then pull the lever at the top center of the door with the + & - on it to the -. then make a coffee. There is a micro swithh in the doser box that can get coffee dust a in it and not operate properly. It may need to be replaced.
Oct 30, 2010 | Saeco Royal Digital Plus Coffee...
My Saeco Royal Cappucino gives hard noise, when "tamping". The grind goes to waste-basket. No coffee..
HI
There is a lever on the top of the door that has a + to the back and a - to the front. Pull the lever back 1 click to the front or - side. Your putting too much coffee in the brew unit and could break the brew drive.
Nov 30, 2009 | Saeco Royal Professional Espresso Machine
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
After a tons of browsing and debugging finally I got the real solution to my similar problem with a Saeco Minuto HD8763 coffee machine: the root cause was a bad hall sensor and a weak magnet at the grinder toothwheel (the left magnet whcih was removed from it's original place). The upper one was okay and down under there is the replacement magnet which I made from a piece of HDD neodymium magnet and glued to fix it.
The original hall sensor was marked as "210k 3491" ("HAL506K" based on some other service manuals) and the new one was a cheap non-smd but same size, unipolar "TLE4905" type.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Ground coffee Saeco Royal
Hi
thedalys. you probably have a bad micro switch on your doser. and that just needs to be replaced. If the grinder does not sense that the doser box is full it will keep grinding until it times out.
Guest. Try pulling the dosage lever back one click from the full and push your grind lever to the largest # and see if that helps. Sounds like you grinds are too fine and its clogging the the grind box. If the dosage level is too full it will cycle and dump the brew unit or break the brew drive gears, then you will hear a clicking noise when it trys to make a coffee.
Dec 12, 2008 | Saeco Royal Digital Plus Coffee...
Not making espresso from beans
Hi
Are your coffee grinds wet? If they are you have a clogged brew head. Remove the filter screen. Then remove the 2 screws that hold the outlet manifold to the brew head. There are 3 things under the manifold. O-ring, tapered spring and a crystal ball. Don't lose any of these items. Now to clean the brew head turn the brew unit over to where you can see where the brew screen was. You will see 2 holes, 1 large and 1 small. Take a paper clip and straighten it. Turn the brew unit upside down and insert the paperclip into the small hole. Push the paper clip through and remove the plug. I have seen them over 1/2" long. Reassemble the brew unit crystal ball first, small end of the spring on top of the crystal ball, place the o-ring over the spring and place the manifold on top making sure the outlet pipe is to the outside of the brew unit. Put the 2 screws back and your ready to go. Run a detergent for espresso machines like Cafiza through the brew unit every once in a while to keep it clean. It doesn't take a lot of detergent and use the pre-grind setting and a large cup selection but don't put any coffee in.
Nov 25, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Machine grinds but doesn't brew
Hi Donna,
Try to factory reset the machine in the meny.
Apr 13, 2008 | Saeco Royal Exclusive 30153 Espresso...
Loud clicking and no coffee
Looks like your brew drive gears may be stripped. You should have a professional look at it because some must be causing the struggle to happen.
Saeco Service and Parts
www.cerinicoffee.com
Nov 26, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
498 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
