Question about Dishwashers
Whirlpool dishwasher heating element overheating
The heating element in our Whirlpool dishwasher is getting extremely hot. The model number is GU1100XTLB1. We noticed it because it smelled like burning wax or plastic. When we opened the dishwasher, we found the culprit. What is wrong?
Same thing just happened to my yesterday on my Kenmore. Expert help needed.
Posted on Dec 04, 2009
There's only one pipe for water is it a cold water dishwasher or hot model number adp755
If there is only a single water inlet then it has to be connected to the cold water connection. Generally dishwashers use internal heater elements to heat the water during relevant wash and rinse cycles.
Hope this helps.
Jan 02, 2013 | Whirlpool Dishwashers
Have a whirlpool dishwasher model number 854241615810 The problem is that it doesn't complete a cycle and the start button flashes 3 times then a pause then 3 times . The water doesn't get hot eithe
The three flashes is the error code for a defective heating system. Usually this is a bad heating element that needs to be replaced, though it can also be a faulty control circuit or thermistor.
Oct 21, 2012 | Dishwashers
I need a heating element (i think) for my whirlpool quiet partner 1 dish washer, but i need the model number and I dont have it with me, do you know the part number for the heating element that I need or...
Your Whirlpool Quiet Partner 1 should have its model number inside along the left side. Mine is DU1010XTXT1. Your heater part is original Manufacture # W10518394. Can be purchased for about $38.00 at
http://www.partselect.com/PS8260087-Whirlpool-W10518394-Heating-Element.htm?SourceCode=3&SearchTerm=w10518394
or order an after market heater element part # AP5690151 for about $33.00 at
http://www.appliancepartspros.com/whirlpool-heater-w10518394-ap5690151.html
Hope this helps!
Apr 04, 2011 | Whirlpool Dishwashers
On model du81qdwgq1 is hot or cold connection
You are supposed to connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water.
Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has been shut off for a while. If you have questions, please let me know. I hope this helps you.
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher wont change cycles.
its might be your heating element or the thermostat check if the heating element get hot if not theres your problem...
the machine try to get to sertion temperture and cant do that so it stuck in the same mode...
heater # 8572861 coast 20-30$
Thermostat Number: 661566 = 14$
hop it helps
Jan 22, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Mar 30, 2009 | Whirlpool 24 in. DU915QW Built-in...
Replace the heating element of a whirlpool GU2300
I have a manual but will need to full model number,,
Jul 09, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
869 people viewed this question
Top Dishwashers Experts
