Question about LG LFX23961SW Bottom Freezer French Door Refrigerator
The ice fan is making a loud humming noise - LG LFX23961SW Bottom Freezer French Door Refrigerator
    Guru:
  • 830 Answers
Hello and thank you for using Fixya's services.
I am not an expert in this field but I did have the same exact problem and called a service technician. There was huge block of ice in the back panel of the freezer.
Get everything out of the freezer and take the panel off the back (inside of freezer) with a screwdriver. Look by the fan and check the bottom to see if there is a build up of ice. You can pry it off or take the blowdryer to it.
Please take precaution when doing this and I would unplug the fridge just to be on the safe side.
We paid $180.00 for someone to do this....if I would have known...lol. The technician did tell us we would need to replace the fan eventually but we haven't yet. I would say that it hums (loudly) every six months and we (my husband) have to repeat the steps above.
Hope this helps!
Posted on Nov 19, 2009
Freezer side is making an extremely loud humming sound. Ice maker is working fine. No ice buildup anywhere in the freezer that we can see. Loud humming goes on for a few minutes each hour.
Hey Joanne, I appreciate your inquiry!
Based off my understanding the freezer side of your Frigidaire refrigerator is making a loud humming noise. The humming sound could be coming from your compressor. If the sound is a new development it may be a possible issue with the fan pushing further against the wall. You may need to seek help from a professional technician for proper diagnosis and repair. This will help you from purchasing any unnecessary parts. Hope this information is helpful to you. -Matt
Dec 30, 2015 | Frigidaire FRS23W3A Side by Side...
Loud humming noise coming from fridge
sounds like the evap fan is hitting something.. or is loose and making noise... I would remove the cover in front of the fan and take motor out and reinstall it making sure all washers and grommets are in place...but I would look for ice build up first, this could indicate a defrost problem..... hope this helped ken
Sep 29, 2014 | Bosch Refrigerators
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
Sep 24, 2014 | Whirlpool Refrigerators
Ice maker making loud noise for exrended times on fridgidaire
water will condense and then freeze in the fan area. Need to remove freezer inside back panel and remove ice from fan area. Fan is located abot @/3 down on right side. No permanent fix I have to do it about every three months.
May 11, 2014 | Frigidaire FRS26R4A Side by Side...
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
Fan in freezer section below ice maker makes loud rattling humming buzzing noise. Needs replaced? How do i replace? Thanks!
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
May 21, 2011 | Refrigerators
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Hey everyone-
I recently fixed a similar problem with my freezer. I searched first and found this and a few other sites which listed this and wanted to provide input for anyone in the future.
I have a GE GSH25JSRF SS. It is about 3 years old. Several months ago I noticed when the evaporator fan in the back of the freezer turned on it would make an awful howling or whistling sound. Basically sounded like what you would hear from the window of an older house if the wind outside was blowing real strong. It was loud enough to hear on the other end of the house.
I was convinced that it HAD to be the air blowing over the venting or a gap that created that sound. But I read different solutions on the internet and decided to take a chance on simply replacing the evaporator motor and attached fan blade. That solution worked and my house is quiet again, thank god.
I ordered the parts from a supplier on the internet. Keep in mind, though, if you're not real handy it may be more than you bargain for. Might be easier to have a service guy come out.
I'm still not sure exactly what aspect of these parts caused the howling sound. It could be a bearing within the motor or perhaps the fan blade slipping due to wear. Either way, it's fixed now. Just wanted to share. Thanks.
Oct 04, 2006 | Samsung RS2630WW Side by Side Refrigerator
LG LFX23961SW Bottom Freezer French Door Refrigerator Logo
148 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
