Question about Acer Aspire One Netbook 8.9" Notebook
Acer says this when i sign-on: Windows could not start because of a disk hardware configuration problem. Could not read from the selected boot disk. Check boot path and disk hardware. Please check the windows documentation about hardware disk configuration and your hardware reference manuals for additional information. What does this all means..
  • Jon Hunter May 11, 2010
    What OS are you running? Xp, Vista or?
    Guru:
  • 597 Answers
It's not able to see your hard drive. Something may have changed in CMOS about the boot order. You should enter the bios and see if it sees your hard drive. Then go into advanced boot options. First boot object is usually set to CD Rom for setting up operating systems and the second boot device should be your hard drive. Third boot option can be left at none or a floppy drive if you have one. If the bios is seeing your hard drive and it is set as a boot option then the drive may be damaged or system files have been lost. If there are valuable files on the hard drive and it is failing then you might consider taking this to a professional and trying to rescue your files asap before the drive deteriorates any more than it is. You can also try some repair options from booting off the Window's CD but beware that formating your drive is one of the options and this will erase any files you have on the drive.
Posted on Nov 19, 2009
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
I have a dell optiplex320 windowsxp desktop,i cannot log on,a box comes up saying windows could not start because of a computer disk hardware configuration problem.could not read from the selected...
hello
well I can tell you it either it is Software (windows xp) or hardware your hard drive. you will need the windows xp disk.
IF YOUR DVD TRAY IS NOT OPENING THIER IS A PIN SIZE HOLE NEAR IT AND USE A PAPER CLIP TO STICK IT IN AND POP THE TRAY OUT.
hope the tray opens and then you can move on to a repair install.
here is how to do a repair install 10 steps
http://pcsupport.about.com/od/operatingsystems/ss/instxprepair1.htm
hope that helps
Aug 17, 2013 | Dell Computers & Internet
Asus eee 900 disk hardware configuration
Have you checked BIOS settings to make sure the right harddisk is selected as Boot Drive ?
You could try installing it on another machine to make sure it's still readable.
Did you change any settings or get any error messages the last time you used it ?
Jun 18, 2012 | ASUS Eee PC 900 Notebook
My laptop says windows error recovery
The Windows Error Recovery message can appear for several reasons- an improper shutdown, new software, new hardware, etc. Since trying both options that you are given doesn't work, you need to troubleshoot the Windows startup error. If you have recently added new hardware, disconnecting or removing it could solve the problem for you as it might be creating some type of incompatibility.
Troubleshooting Windows Error Recovery: Last Known Good Configuration
You can attempt to boot up in Safe Mode and select Last Known Good Configuration and see if that works to resolve the Windows startup error. Turn the computer on and immediately begin to press the "F8″ key. If this does not work, you might need to press the "F2," "F10," or "F12″ key. Once you see the prompt screen, select "Last Known Good Configuration."
Troubleshooting Windows Error Recovery: Booting up from the Installation Disk
If that did not work, try booting up the laptop using the Windows installation disk - provided you still have it. If so, follow these steps:
1)   Turn the power button to your laptop on.
2)   Immediately insert the Windows installation disk that belongs to the laptop.
3)   When you see the option for "Check System," press the "ESC" key. Next, press the "F1″ key. Your laptop should now boot up.
4)   You can now use the "System Restore" feature to allow your laptop to return to a previous setting when it was functioning properly. This might mean selecting "R" for recovery.
Mar 11, 2011 | Acer Cell Phones
Windows could not start because of a computer disk hardware configuration problem. Could not read from selected boot disk. Check boot path and disk hardware.
It appears that your system can't find any bootable device such as the hard drive. Go to system BIOS and check if the hard drive is detected. By pressing F2/Delete key while starting up it will boot up to your BIOS screen. You could also try to load the system BIOS default.
Dec 30, 2010 | ASUS Computers & Internet
Windows could not start because of a computer disk hardware configuration problem. Could not read from the selected boot disk. Check boot path and disk hardware. I tried all 10 choices no matter what...
Hard to give all the steps in this venue..go to about.com and type in "computer won't boot", I know the computer guy there, his name is Tim Fisher on that site and he has step by step instructions on what to do...
Apr 19, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Acer Aspire One Netbook 8.9" Notebook Logo
85 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
