Question about Refrigerators
Kelvinator cyclic 220 Impression series specifications
What is the globe and where do i get one?? I am in Brisbane
4 Suggested Answers
abhishek33
  • 1239 Answers
SOURCE: shelf locators broken of the
hi When a refrigerator gasket (usually a rubber seal around the door) becomes hard or cracked, its seal is broken, and the unit's efficiency drops sharply. Test the door gasket for leaks by placing a dollar bill between the gasket and the door jamb and closing the door. Pull the bill out. If it offers some resistance, chances are the gasket fits properly. If the bill comes right out, or falls out, the gasket is faulty and should be replaced. Test the gasket at several locations around the door. Before you replace the gasket, check the door hinges for leakage.
Posted on Oct 17, 2008
  • 1196 Answers
SOURCE: I have a Kelvinator 2
he reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Posted on Feb 26, 2011
bobicehouse
  • 1524 Answers
SOURCE: I have a Kelvinator Impression series 195 Cyclic
Indication of a refrigerant charge problem.
Posted on May 19, 2011
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Where abouts is the thermostat inside the fridge there are white and yellow wires that go to either side of the fridge and the yeallow ones are broken what are these wires for it is a kelvinator C375vm
It sounds like you have a cyclic defrost fridge,Kelvinators were originally fitted with heat assist thermostats,so in order for the fridge to come back on a yellow wire heater was run around the cooling evaporator in the fridge compartment start running again at approx +4C so when the element fused the fridge did not start again until approx +12C.So instead of replacing heater a different thermo was used that came back on at +4c deg regardless.Kind Regards.
Jul 09, 2009 | Refrigerators
I have a Kelvinator Cyclic 501 Impression Series fridge. Model C501V-R. no matter what setting it is on everything is freezing - the door seals are in excellent condition.
I used a,Hair Dryer on mine that fixed it, had too do it twice though have not had a problem since, (it froze the entire Thermostat over), had my Fridge for over 30 years only ever replaced the seals recently, no other problems ever
Jun 11, 2008 | Refrigerators
Refrigerators Logo
388 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
