Question about GE Profile Performance 25.2 cu. ft. Side-by-Side Refrigerator with Dispenser TFX25PPBWW
I have ge profile refrigerator tfx25pr with icemaker and water dispenser. I'm trying to find where the water filter is. Where would it be?
  • 14 Answers
THIS MODEL DOESN'T HAVE A FILTER
Posted on Nov 19, 2009
GE Profile Icemaker freezing up; water freezes down inside wall of freezer; icemaker making ice, very slowly, but will not dispense. Water is still dispensing
This sounds like your water valve is not completely closing allowing water to drip and freeze. First check to make sure that the water tube going into the cup of the ice maker is lined up correctly and not causing this problem - if it is lined up correctly then replace the water valve on the back of the refrigerator that your main line is connected to.
Jul 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile arctica side by side- ice maker and water dispenser not working..have already replaced the water filter
The water dispenser and the icemaker both operate on different soleniods on the water valve so the chances of a bad valve are slim. I would assume you issue is in your water supply. The easiest thing you could try first would be to check your saddle valve that taps into your main water line to supply the ref. They are known for calcium deposits which obstruct the flow of water. This issue is IDed by very slow water pressure through th door. If its gunked your icemaker fill tube may also be frozen.
Jan 11, 2010 | GE Profile Arctica Stainless Steel Top...
Ice maker stoped working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Jun 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Blocked defroster drain GE profile tfx25pr, tft25pr
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
May 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Location of ge profile water inlet valve
may be to much water trap door open light on door (ajar)
Mar 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
The water is not working, yet the icemaker still works
sounds like the water tank in back of refrig is freezing up ,,,,, turn temp down and allow 24 hours for it to make adjustments
Nov 30, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
1,326 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
