Question about Sony Playstation 3 (PS3) Console
Playstation 3 Hi, I was playing my PS3 on my HD projector through the HDMI cable, everything worked until i decided to take the cord out of the projector and hook the PS3 up to my T.V, with the PS2 i could unplug the A/V cords while consol still turned on, but with PS3 i tried and nothing happens, the T.V acts like nothing is hooked up, help plz?
  • 4 Answers
How down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Posted on Jan 12, 2008
Try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
My playstation 3 will not play in 1080p. It used to work, but when we switched cables, it wont work in HD.
When you switched cables, you mean you changed the cord running from the PS3 to the TV? HD content requires an HDMI connection from the PS3 to the TV. It is possible that when you changed cables, you replaced the PS3's HDMI cable with Component Cables which can only deliver in Standard Definition and not in High Definition (720p, 1080i and 1080p).
HDMI:
http://www.playstation3hdmicable.com/images/hdmi2.jpg
Component: http://www.componentcable.net/images/Component%20Cable%20PS3.jpg
Apr 29, 2011 | Sony Playstation 3 (PS3) Console
Can a PS3 output a dvd movie to a projector? And if so, is it straightforward?
if its standard av cables than it would be the 3 colors pluged into the projector for hd projetion it would most likely be a hdmi cord the setting for hd are in video ps3 launces in last know configuration so standard would carry over
Dec 08, 2010 | Sony Playstation 3 (PS3) Console
How do you set up a ps3?
I would suggest you follow these procedures, hook up your PlayStation 3 to a television. You must decide whether your TV supports high definitions (HD) resolution or not. For HD resolution, you must use a HDMI cable or a component video cable. These cables also support standard definition (SD) resolution. If you only have an SD television, you can use an S-video cable or an AV cable. These two can't support HD resolution.
Connect the PlayStation 3 to any audio equipment such as a A/V receiver or home entertainment system. Connect using a digital audio cable or, alternatively, run an HDMI cable to your A/V receiver then another HDMI cable to the television set.
Plug in the Ethernet cable, then connect the other end to a 10Base T jack from your home network. This connects you to the Internet and the world of online gaming.
Attach the AC power cord to the PlayStation 3, and then plug it into a surge protected wall outlet. Don't plug in the power cord until all other connections have been made as a chance of shock exists.
Perform the initial set up of the system. Turn on the power of the TV and game console, and follow the on-screen prompts. The pre-installed software guides you through the set up process.
Take care.
Jul 18, 2010 | Sony Playstation 3 (PS3) Console
I bought a hdmi cord so my son can play ps3 we
Hi:
Check the video connector on the PS3 for a switch to switch from composit video to HD video.
Dec 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Ps3 broken
When you attach your Play Station 3 to an HD TV through an HDMI port, the Play Station 3 will ask you if you wish to switch to HD Mode.
However, if you decide to move it to another TV that is not HD compatible, you will get no picture because the Play Station 3 is “stuck” in HD (HDMI) mode.
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
That’s it! You can play your Play Station 3 again!
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
PS3 to Infocus LP 350 projector using HDMI
M1-DA is a type of DVI connection that produces both analogue and digital signals, the easiest and most quality source cable for you to get is a HDMI to M1-DA cable which is now widely available for purchase.
Infocus should have included this cable in with your projector, but instead the power at bee decided to put a M1-DA to DVI-D cable instead when most visual devices now support HDMI and not DVI nowadays.
Thanks
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
PS3 game graphics **** after playing PS1 game
1080p mode is HD mode and the ps3 must have a HDMI cable connected to the ps3 and tv for those graphics to take affect
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Cannot get my HDMI cable linked from my ps3 2 my hd tv
Try video settings on the playstation 3. Adjust it to reflect hdmi.
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
