Question about Dell F3534 Touchpad
My cursor flies all over the screen and ends up in the top right corner of my screen all the time no matter what i'm doing. It seems to right click as it does it. Why is it doing this?
  • 380 Answers
Your touchpad is not working right. Use a USB mouse and disable the pad until you can get the pad replaced. Also, check the mouse drivers to make sure they are correct and up to date.
Posted on Nov 19, 2009
Testimonial: "I had a feeling that was going to be my answer to this problem. Thank you for the help!"
How do I get my screen back to normal. it is too far over to the right. I cant hit the maximize box
What computer are you using?
On a Windows pc use the key combination ALT+TAB to switch between active windows
Then either:
Double click the Title bar of the window which is partly off-screen
Or - press the F11 key
Or - Click and Drag the title bar to the top of the screen then release the mouse button
One of these methods should toggle between full screen and where it is now
Or - Hover your mouse over a corner or edge of the troublesome window until the cursor becomes a double ended arrow - Then click and drag to re-size the window - Then click and drag the title bar to get the full window back in view
Jan 02, 2017 | Computers & Internet
HOW DO I REDUCE SCREEN TO SHOW UP=DOWN TOOLBAR ON RIGHT SIDE
when on google top right corner of page tools icon 1 left click zoom to page size required
Mar 04, 2015 | Compaq Computers & Internet
Where do I turn off my laptop
Power button is top left corner of keyboard above the "Esc" key.
If you are trying to shutdown from Windows 8, follow these steps:
1. Mouse over the little gadget in the lower right corner of the screen. (You can also move your mouse cursor to the upper left corner; same result. Or, you can press Windows-C on your keyboard.)
2. In the slide-out menu (known as the Charms Bar) that appears, click Settings.
3. Click the Power button, and then click your desired action: Sleep, Shut down, or Update and restart.
Mar 07, 2014 | Dell Computers & Internet
Recently, when getting a website, they all show just the top and I have to enlarge them. How do I fix this to get a full screen webpage the first time?
Please perform the following step to have your browser to open always in maximised screen:
Click IE, and open the browser, and when you do it the first time you will still have the browser in minimised screen. And now hold the cursor on the corners of the screen and drag it till the screen touches the end of the screen and when the browser looks maximised, Perform the below step and exit the browser.
Hold the "CTRL" key, select "File" and click "Exit." When you reopen Internet Explorer, it should open maximized.
And from now on when ever you click on the browser to use it you
will get it in full screen mode.
Jul 18, 2010 | Microsoft Windows Vista Home Premium...
How do i get my start button on the left corner of my screen? it is at the top right now.
The Start Button is on one end of the "Taskbar"
Use your mouse to move the cursor anywhere on the task bar, click-and-hold, and drag the taskbar back down to the bottom of the screen.
If it won't move (you try to drag it but it's not going anywhere) then right-click on the task bar and un-check the menu item "Lock the Taskbar" then try again.
If this helps, hit the "thumbs-up" for me.
If not, use "add comment" to ask any questions you might have, then check back for answer from me or another FixYa expert!
Jun 18, 2010 | Computers & Internet
Loaded mozilla and screen did not appear fully.
Right click on the bar along the bottem of the screen, and a menu should pop up, near the top of menu click cascade windows, the mozilla window should go to the top left corner of your screen. with the mouse cursor go to the bottom right hand corner of the window and an arrow should appear keep the right click button held down and drag the window diagnally towards the bottom cornner of the screen and you should then have full screen window.
Jan 22, 2010 | Mozilla Firefox
Toshiba Satellite A215-S7437 will not boot up...
Take out the hard drive completely and then see if you hear the clicking noise, if you do then that means the hard drive is bad. Also if it goes right to another message and you don't see the blinking cursor then that also verifies that the hard drive was bad and causing the system to hang.
Jun 12, 2009 | Toshiba Satellite A215-S4747 Notebook
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Drfting cursor
This is a well known occurance with laptops and is not something you can fix. Occasionally the manufacturer will release a patch to try and help, but this is very rare.
May 22, 2008 | Toshiba Tecra M2 Notebook
Computers & Internet Logo
195 people viewed this question
Alun Cox
