Question about Cell Phones
A red page with this codes apears: BP_NOT_REDY BOOT MODOULE: BOOT_G_00.02.50R_HAINAN MBM FLASH MODE BATT TRICKLE CHRG DISABLED thank you
I cannot turn on my phone. Error message comes on MBM Flash-mode. DUOT Version:02.06
May I ask what ie the model of your phone?
You can also try to hold the Power button down until this "secure boot enabled" window closes. Then try to reboot the phone , to see if that resolve your issue.
Jun 28, 2014 | Motorola Cell Phones
Tip
Determining the State of Charge of Your Nuvi 350 Batttery
To view the state of charge of the battery in your Nuvi 350 hold your finger over the Time Display in the upper right corner on your Menu Screen for 8 to 10 seconds This will put you into an Information Mode the first screen of which starts with:
SWVer 5.10 nuvi1x2GB_2CS
Touch Next 4 times and you get:
Battery Test Page
Batt State Ok Cap
VBattery 4.07
BattCap 93
Bat Chrg1mA -198
BatChrg mAhr 1207
Chrg Cycles 3
on Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
Phone not starting
BP_NOT_READY BOOT MODULE BOOT_G_00.02.21P_MACAU MBM FLASH MODE please help me
Sep 27, 2013 | Motorola Mobility ROKR E6 Smartphone
I have forgot my locked code? please help me
flash your rokr e6 . and your code is be default ....
for flash help go to this link..http://www.gsmindia.in/forum/p2k-series/11437-flash-your-motorokr-e6-at-home.html
or try this step..
Go to your Dial Pad and dial: WWW008W. To make the W hit the menu button while in the dial pad, then hit insert->insert wait to make the W .
You should see something like:
R533_G_11.12.08P
BP: R533_G_11.12.08PB
PFlex: GSZMCAUT678SW016
DSP: 63343400 TECHNOLOGY
Look at the numbers at the end of the first line for the version. The version shown here is .08P.
The Following are all Generic Firmware
R533_G_11.12.02P
R533_G_11.12.06P
R533_G_11.12.08P
Change Log - Nothing has changed until 08p which includes an EQ for Real player & Screen 3.
1. Download the file Motorola_USB_Driver_32_v2.7.6 to your PC and unrar it to your desktop so you can easily find it.
2. Install a program called "RSDLite" on your PC. To Download RSD lite Click thread for the file. For trouble free installation, if you are running Windows XP, you should have Service Pack 2 installed.
3. Download the firmware file that you want to flash to and unrar it to your desktop.
4. Start up RSDLite on your PC. You may be asked to install a number of drivers (5 or 6) to your PC. Point it in the direction to the motpcsdrivers folder you unrared.
5. Put the phone in Bootloader Mode - MBM mode by turning on phone while also holding down the Camera Button and the On/off button (These need to be all be held down together). The phone should start up with a red screen and say its in MBM mode.
6. Plug phone in using usb cable.
7. RSDLite should list the phone (this may take a minute or so. If it does not close down RSDLite and restart it). Start the flash process, by clicking the button on the top with the ??? and select the firmware file to install then click ?Start?. The process will take several minutes so be patient, the screen on you phone will turn off, but RSDLite will still show progress.
8. When the "Found New Hardware" screen pops up, select ?NO? for ?Can Windows connect to Windows Update?? then select ?Y? for ?Install Software from a specific location? and point it to the motpcsdrivers folder you unrared. Once the driver has installed, click on ?Finish? on the ?Found New Hardware wizard? to continue the process.
9. You will need to install quite a few drivers ? so just keep repeating. It may ask you to manually restart the phone ? if so, unplug the cable from PC, remove the battery for 5 seconds (make sure unplugged first!), put battery back in then turn phone back on.
10. Once its fully on, go to Setup --> USB Mode and change mode from "Mass Storage" to "Modem".
11. Plug phone back into the PC using the cable. RSDLite should say "complete" or ?PASS?
12. Unplug the phone again, turn it off and on. All should be complete.
You can now restore all your contacts, calendar and tasks back to your phone using MPT. (Be sure to remove the SIM card before doing this as the recovery function from MPT deletes any contact on SIM for some reason!)
Try This This Helps
by....ASHISH KUMAR
Jan 29, 2011 | Motorola Mobility MOTOROKR E6
Screen of my motorola ROCKR E6, has become red coloured, and the text written on that is- BP NOT READY Boot Module Boot_G_0002.2IP_MACAU MBM FLASH MODE. Is there any solution for this problem. Thank...
dear sir
this is the problem usually caused by viruswhich happens when you are receiving files from p.c or untrusted mobiles...... and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur phone software from the nearest motorola service centre,it also updates your mobile software which increases the mobile speed....
thank you.....take care................
Oct 05, 2010 | Motorola Mobility ROKR E6 Smartphone
How can I flash my Motorokr E6 Cell Phone?
R533_G_11.12.08P
R533_G_11.12.02P
R533_G_11.12.06P
R533_G_11.12.08P
Try This This Helps
Regards ,
Zubin
Feb 10, 2009 | Motorola Mobility ROKR E6 Smartphone
Red Screen w/ message
May i know how to solve this issue and turn back in to normal mode
Oct 06, 2008 | Motorola Mobility A1200
I need to turn red eye off on my olympus e 510
Hi - You can download the manual from the link underlined in blue below:
olympus e 510
See page 34:
Select a non red eye mode.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 03, 2008 | Olympus Cameras
Mode could not have been initialized when i play mortyr game
The phone ain't responding... It says bp not ready, mbm flash mode...
Nov 17, 2007 | Motorola Mobility A1200
Cell Phones Logo
50 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
