I have a National Microwave Oven ("The Genius") and can't find how to change the globe, as it has blown. Could someone please tell me where the globe is situated and how to change it.
Thanks heaps
Kabby
The model you gave was for a microwave oven. In the backside of the microwave is a air cooling window. If it gets clogged with junk the mag will overheat and the limit on the side of it will shut down the oven. Simply cleaning this area so that air can circulate better can cure the problem. I suspect it finally got so bad that the cavity thermal limit has blown now and you have nothing at all. I have a service manual and more HERE
Try the Panasonic website below. National became Panasonic a number of years ago. I just went there and did a search for demension 3 under microwaves and it definitely has a few results for instruction manuals. You will need your model number (most likely on the back of the oven)
Usually you have to remove the oven from its shelf, unplug it and remove the outer case. you will then find the globe to change.
Don't operate the oven unless the case is screwed back on
