Question about HP Officejet 5610 All-In-One InkJet Printer
I put the black cartridge #56 into the tricolor in an HP 5610 Off
I put the black cartridge #56 into the tricolor #22 slot and cannot get the black cartridge out of the color slot. STUCK! Help please. HP OfficeJet 5610
    Brigadier General:
  • 10,406 Answers
It just is "jammed" into place, like a round peg into a square hole.
Use a bit more strength, in order to "unjam" it.
Or, if you are not comfortable, take it to a qualified printer technician,
and let him/her remove it.
Posted on Nov 19, 2009
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
My pc says printer in back up mode
that means either the black or tricolor cartridge ran out of ink and it's currently utilizing only one cartridge.let say you ran out of blank ink but tricolor cartridge is still good you can still print or make a copy using only one cartridge but the quality won't be that good
May 31, 2011 | HP DeskJet F4180 Inkjet Color All-In-One...
I have a HP C4780 printer - does the 300XL cartridge work on this model
The HP Photosmart C4780 All-in-One does not use HP 300XL Cartridge.
Below are the cartridges used by your printer with the no. of page count and their price as per HP
HP 60 Black 200 pages $14.99 HP 60 Black/Tricolor 200 black, 165 color $31.99 HP 60 Tricolor 165 pages $19.99 HP 60XL Black 600 pages $34.99 HP 60XL Tricolor 440 pages $40.99
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 04, 2011 | Office Equipment & Supplies
The tricolor cartridge status light is blinking. I want to print with the black cartridge as I always do. I have hardly used the tricolor cartridge. It cannot be empty. The printer will not print. I have...
Ink cartridge will go dry up if you don't use them. I would try cleaning the head and do some maintence on it. It looks to me that you have to buy a new black cartridge. I went through the same thing on mine.
Nov 15, 2009 | HP Deskjet 6940 InkJet Printer
F4235 cartridge will not fit in slot
Hello.
Be certain that you are using the HP 60 (CD947FN) Black/Tricolor Ink Cartridge.
If you have the correct cartridge, it should fit and just snap into place.
Hope this helps.
Nov 13, 2009 | HP DeskJet 920c InkJet Printer
I have a hp desk jet 5440 i put i a new tricolor
Make sure that your buying a new Tricolor as the same and Geniune too.
Only solution to this is put it properly inside your printer.
At first sometimes New Cartridge are being initial & calibrate by your printer before it works.
Power Off first your printer and put the cartridge inside. If the problem still exist then put back again your old cartridge and identify what is the problem occur before you put a new cartridge on it.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
Want to change cartridge on hp PHOTOSMART C4480
Look at the front of the printer and you will see a slot in the center of the front. Reach into that slot and pull forward. That will open and allow access to the cartridges on the right. Grab the cartridge you want to change and pull down slightly and out. Remove the tab covering the connections on the new cartridge and reverse the procedure to install.
Jun 04, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
My printer is HPpsc 1610 and I am out of black ink. May I use HPtricolor#95 instead until I can buy the black? I have 3 of them on hand.
you can not replace the black ink cartridge with a color ink cartridge. the printer will not recognize the tricolor that you will put in the black cartridge area
Aug 13, 2008 | HP Office Equipment & Supplies
Hp photosmart 7350
The 7550 takes three cartridges 56(black) 57(tri-color) and 58 (photo).
If you replace the 57 but the 58 is also empty and still in its slot - you get green tinted photos.
So, check to see if you have the 58 photo cartridge still installed, and if it is out of ink. If so - remove the 58 - the printer will then default to "reserve mode" and you'll get better color.
Dec 16, 2007 | HP PhotoSmart 7350 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
250 people viewed this question
Seeker5211
Seeker5211
