Question about Compaq Presario Laptop
I own the above laptop, my hard drive had recently crapped out on me so i went and purchased a new one, i inserted the hard drive, the computer seems to see it in the ROM setup and I am able to do a HDD self test to 100%, but when I goto install an OS it tells me i have a non system disk. I have tried switching the jumper from master to slave, vice versa, completely keeping it off and i still end up with the same result. Help plz?
  • 1,959 Answers
Apparently, the hard drive needs to be formatted with a logical drive to install the OS. If you've no format software, go to the following link:
Gparted Live CD to download an ISO which is bootable from either a CD or flash drive (assuming you can boot from a flash drive on your machine, check BIOS boot order for availability) Once installed follow the instructions on that same download page to create a boot partition. Once the logical partition has been created, you should be successful in installing your OS. Best of luck!
Greg
Posted on Nov 19, 2009
    Scholar:
  • 101 Answers
What OS are you trying to install? If it is XP and the HD is SATA you may need to set the SATA driver in BIOS to legacy OS. Hard to believe XP is legacy but I have had this issue w/Compaq laptops.
Dear ... I have recently purchased Seagate's Freeagent External Hard Drive (500 GB Capacity). It was working all right for about 10 Days, but now I face a peculiar Problem. This drive does not show in the...
Plug it back in and try this. Right click my computer and click "Manage"
When the window opens select "Disc Management". In the bottom of the screen you will see all the Disk drives installed on you computer. Right click on your drive and select "Properties". When the window open click the "Tools" tab and finally Run the Error Checking Tool. It will scan and fix any issues with the disk. Cheers :)
Jun 27, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My external hard drive had the click of death. I
YOU HAVE TO PUT IDE OR SATA CABLE TO THE DRIVE AND ONE MORE THING IS 4 PIN SUPPLY FROM SMPS.YOU HAVE TO PUT CONNECTIONS LIKE THE FIRST HARD DRIVE ALREADY IN THE COMPUTER
Apr 04, 2010 | Computers & Internet
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
I have dell inspiron 1525 c2d with 250gb hard disk
tru following steps
1) plug in usb device
2) change your boot option to cd from hard disk
3) insert installation disk in cd drive.
4) follow the steps.
5)finalize instalation.
Enjoy !!!
Mar 18, 2009 | Microsoft Windows 98 for PC
Acer Desktop won't boot after recovery
Why not use your new hard drive as a storage disc. Reconnect your old hard drive as it was before. Hopefully it will boot the computer again. If it does, shut down the unit. On the primary bus, set your old HD as master & the new HD as slave with jumpers. Boot the unit & hopefully you will now have a "c"&"d" HD showing in My Computer. Remember that your are dealing with Windows & what should happen & what really happens can be two entirely different things.
Dec 14, 2008 | Acer Aspire™ T180 PC Desktop
IRQL_NOT_LESS_OR_EQUAL
1. purchase a 2.5" usb enclosure.
2. remove your hard drive and install in the enclosure.
3. plug the enclosure into a working computer and copy or move your important files onto working computer.
4a. reinstall the laptop hard drive and try a repair installation by booting from the XP cd. (if you are running xp)
4b. reinstall the laptop hard drive and try booting to Last Known Good Configuration. Press either the F5 or F8 key while rebooting to get to the menu.
4c. purchase a new hard drive and reinstall the OS using the reinstallation cd's
Dec 09, 2008 | Dell Inspiron 1501 Notebook
Verbatim 120GB external hard drive
goto Control Panel, administrative tools, Computer Management, Disk Management, If it pops up a new disk install wizard follow the directions in it. If not then find the new disk that has no partition on it, right click on that drive to create a partition, then right click on the drive to format it, if it hasent done so already.
Mar 16, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Laptop won't boot
its is possible that the adapter is had it! Get hold of another to test and if goes then all you need to do is buy a new one.
Nov 19, 2007 | Toshiba Satellite M35X-S161 Notebook
Compaq Presario Laptop Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
