Question about Fisher and Paykel GWL11 Top Load Washer
Washer will not fill with water. The drum moves, everything seems to work but no water comes into the machine? toyhon@excite.com
  • 111 Answers
Youve got lint or dirt in the float level tube, or the float level switch has gone bad, or the wate shutoff solenoid gave up the ghost.
Posted on Nov 19, 2009
The machine constantly stops for being unbalanced
Go to the entry by moderator taran_2005:
http://www.fixya.com/support/t7125869-kenmore_oasis_washer_goes_ul_even_no
You will find an excellent explanation of "Unbalanced Load" and what to do
Jun 30, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Washer leaking water
Hi there.i have a feeling that maybe the thin tube that runs from the water level pressure switch has come off the righthand side of the bowl & water is coming out of it.if thats the case the machine would never stop filling even at lowest setting.can you let me know what you find.
Jun 03, 2010 | Whirlpool LSR5132PQ Top Load Washer
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
My washer fills up, but not inside the machine. If I put the machine on spin, the water drains out. Why won't it fill inside the machine?
The water is going into the machine, but somewhere below the inside drum. I can hear it sloshing around if I move the inside drum. If I put it on the spin cycle, it does not spin, but the water comes out of the hose and into the sink.
Nov 09, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
How much water does it use
is the level above the drum by at least by 2" during a normal wash fill? are the clothes getting wet through? if so this may be an eco type washer allowing a minimal amount of water in. does the level get higher on a rinse fill?
Mar 16, 2009 | Washing Machines
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
95 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
