Question about Roomba Robotic Floor Bagless Vacuum
My Roomba brush is not working properly -- turns,
The last 2-3 cleaning rounds, the dirt cup was empty at the end of a cleaning session, and this is NOT normal. The filter DID have the usual dust on it. So tonight, I unscrewed several layers, cleaned out debris, and replaced the parts and the brushes. But this time, after turning it on, Roomba made a clicking sound every few seconds. I removed the dirt bin to look at the brush, and it would make 1/8 turn, click, and stop -- then turn again and click and stop turning -- and repeat, repeat.
What can I do?
SOURCE: Roomba Discovery
I read somewhere that you need to clear the software in case there is a glitch. To do this, take the battery out and then, simultaneously hold down the "spot" and "clean" buttons for 30 seconds. Replace battery. This has worked for my Discovery model.
Posted on Oct 10, 2008
Try to turn the brushes by hand, while the machine is off and on it's back. If the brushes will not turn, the brush motor is burned out. If you are mechanically inclined you should not have too much trouble replacing it.
Remove the bumper, then the case. You will see a motor with a long square shaft. That will be the motor to replace.
Personally, I recommend the RobotShop for buying a replacement motor.
Posted on Nov 13, 2008
SOURCE: "Please clean Roombas brushes"
Same thing happened to me. After "cleaning" the brushes and emptying the filter several times, I realized that the brushes were not properly secured. One of the yellow fasteners needed to be pushed closer to the middle nearer to the brushes. It was not secured properly. When I did this it fixed my problem.
Posted on Dec 28, 2008
SOURCE: Roomba works but the dirt stops at the filter. New filter did not help.
The robot dirt tray has a vacuum motor to assist the dirt flow from the floor brushes. Yours is not working. recheck the connections on the dirt tray.
Posted on Mar 25, 2009
57 varieties
  • 1653 Answers
SOURCE: Our Bissell Cleanview II 3576M does a great job
Contact Bissell Direct for a parts diagram and support at
Posted on Sep 11, 2009
Brushes dont turn
If you are referring to the two main brushes underneath the Roomba (not the side-sweeper) then there are a couple possibilites:
1. The gears need to be cleaned/regreased inside the brush unit. There are several videos/guides online that will show you haw to dissassemble the gears, clean out the gunk, and reassemble. Basically there are four screws that hold the unit in; once it is removed you will see several screws on the side of the unit that contain the gears for the brushes. Dirt/dust/hair makes it's way into the gear-case and gums up the works, which seizes the motor.
2. Another possibility is that the electric motor that drives the brushes needs tp be cleaned or replaced. My Roomba had lint/hair caught up in the electric fact the dirt was separating the brushes from contacting the rotor inside the motor, which means they weren't cunducting electricity. Once I cleaned out the motor itself, the brushed worked right away! There are a couple view holes on the sides of the motor...get a flashlight and look inside...there is probably lots of junk keeping the motor from working properly.
Apr 17, 2014 | iRobot Roomba 530 Robotic Vacuum
I starts and tehn stops and beeps three times. I can start it aain and it will run but then it does the same thing'
TYhe iRobot Roomba has different model designations. Here is a webpage with a list of what the beeps mean in the 400 series. I am thinking that is what you have. 3 beeps means the dirt cup is dirty, filters are dirty, or debris in collecting and it needs to be cleaned.
Here is the webpage:
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | iRobot Roomba Discovery SE Bagless Robotic...
Roomba appears to be working fine, goes over the whole house with no trouble, but then house is still dirty and no dirt is in his dirt bin.
if there is dust in the filter and none in dirt bin check to see if brushes are turning, you can do this by running the roomba with bin out, if not turning clean thoroughly, remove yellow tips on ends to check for trapped hair, replace brushes and turn them manually in one direction a few times and then run roomba again, you may need to do this a couple of times
Sep 08, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba does not fill upper tray.
brushes are not turning, you can see this if you remove dust bin and start the roomba, remove brushes clean thoroughly removing yellow end pieces as well to remove trapped hair, re inbstall brushes and turn manually about 20 turns and re try cleaning, try this a couple of times
Jul 06, 2010 | iRobot Roomba 530 Robotic Vacuum
On the white roomba 530 - does not fill big dust cup anymore
you may need to clean the ends of the roller brushes.pull both out pull off the funny looking yellow ends and clean out hair ect.
Jul 03, 2010 | iRobot Roomba 530 Robotic Vacuum
It starts and for a few seconds and then stops The battery is fine
Is the charging ase turned on and is the dust container emptied? Any obstructions?
Apr 11, 2010 | Roomba Robotic Floor Bagless Vacuum
IRobot not picking up dirt
try to replace the filter, that should work.
Feb 23, 2009 | iRobot Roomba 530 Robotic Vacuum
Roomba keeps saying clean brushes yet are clean!
Remove the Yellow connectors on the end of the brushes and clean around the pin well. If there is too much there, the roomba thinks there is something stuck and goes into clear mode (as if there is a chord stuck).
Dec 26, 2008 | iRobot Roomba 560 Robotic Vacuum
Dec 20, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba Robotic Floor Bagless Vacuum Logo
240 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
