Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Sir,about my t.v.Its 42"same shape as in given picture but its no. is DRC-MF/MID. The problem, mild in reddish Color in B&W mode (not proper white balanced) Thanks if u reactify my problem by giving me its password related to service menu.so i can addjust its white balance.if it can be addjusted by pree-set then tell me that where i can get that pree-set in projection t.v. & how they addjusted? thanks
  • Sony Master
  • 8,457 Answers
Tries reset all setting in the menu to factory setting u should get the correct colors.Reset all setting,that said reset.
Posted on Nov 23, 2009
The picture colour of my set is a mixture of blue,red & green. how do i set the color ? please help
try to adjust in color set up menu, if can not get with manual adjustment the problem it could be the convergence ic is defective or an open resistor.
Aug 03, 2012 | Televison & Video
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
Dec 26, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I`m in japan and have no idea what this front load ic card does on my sony DRC-MFV1/MID-X KD-28HD600. Any info at all would be helpful . thank you so much for your time mchael
There are two slots on my 42 inch version. One is behind the front access panel and is for the subscription TV service called BS/CS and the other is for a Sony Memory stick to directly display pictures on the TV in a slide show.
I had cable TV in Japan so didn't need the BS/CS service. My TV was bought in 2003 so is a bit old now - not sure if yours has the same features. Model of mine is DRC-MFV1/MID-X MBD-HXIP
Feb 28, 2011 | Televison & Video
My Sony trinitron drc-mf has now got a sort of negative screen (reddish black) with the actual picture of the DVD player,satellite TV,video ....etc but the menu,channel numbers........etc are all normal
If the Menu Display is normal. DRC module is faulty.This module is installed vertically and has a stainless steel cover, beside Tuner module. If you can do, try to remove the DRC Module,and clean its terminals with paintbrush then put it back properly, if it doesn't work replace the DRC module.
Nov 05, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Television switching itself off with red light flashing.
Had same problem on a 50inch wega tv. It needed lamp replaced,not hard to replace about $180.00
from Sony.
May 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture changes focus/sharpness instantly and then recorrects
Hi
You can try and get more infornation for me.
Go into the the menu by pressing the WEGA GATE button on the remote. In the sub menu of picture adjustment switch the DRC-MF setting to off. It should read normal.
See if this stoppes your focus problem.
If it changes let me know for further directions.
Feb 24, 2008 | Sony KP-57WS500 57" Rear Projection...
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
