Question about Microsoft Xbox 360 Console
My xbox totally quit working and is flashing red lights now. What can I do
  • Rod Sims
    Rod Sims May 11, 2010
    Are you able to take your unit apart ? If so then you could fix it your self Or would you just want a repair shop to fix it ? I will walk you threw if your good with your hands /tools ps don't waste your money on thoes stupid repair guides there a ripoff Rob
    Problem Solver:
  • 6 Answers
That is known as a red ring of death. (RROD) you have to contact microsoft and send it to them to fix
Posted on Nov 19, 2009
  • Chadmoline Nov 19, 2009
    But if you still are under warranty Xbox will repair or refurbish that one for free?
When i turn my xbox 360 on the green light stays on for 30 seconds and then turns red and wont play what would be wrong
While on the RED light. Press and hold the "SYNC" button (don't let go if it during any of the stages). Now press and release the "EJECT button. Note the amount of flashing lights. Do this three more times (still holding the sync button) each time noting the amount of lights that flash. This will give you a total of 4 numbers. Go here to see what the issues is. https://xbox-experts.com/
Oct 19, 2014 | Microsoft Xbox 360 Console
3 flashing red lights
You have the red ring of death. Call microsoft (1-800-4my-xbox). If its out of warranty, you are totally, SOL; you'll have to repair it yourself, or shell out $140 for a new one.
Feb 09, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox360 has one red light flashing
1 red light usualy means hardware failure. There is another error code you can get of of xbox. While machine is on push the the sync button on console and while sync is pushed in press eject button. The lights on the console will give you youre first digit. Theres 4 in total. Repeat pressing the sync and eject button till you have got the four digits and console is back to the red light.
When getting codes the lights will light up. 1 red light means 1 2 means 2 and so on. 4 red lights means 0. Let us know and ill get back to you.
Apr 05, 2010 | Microsoft Xbox 360 Console
Flashing red light
you have what is called "The red ring of death", you can do a couple of things (in this order):
1) Turn off the xbox 360 console, let it rest for an hour or two. If the red light is still there, then do step 2.
2) Wrap a towel completely around the xbox and leave it on for one hour. This will overheat the xbox and somehow gets it to start working again, but only for a short time of maybe a day or two. But, if this doesn't work, then do Step 3.
3) Go to the Xbox website and talk to a customer service agent, tell them your problem. If you are still under warranty, then they will ship you a box to send your xbox to them, it will take a couple of weeks before a brand new xbox 360 is shipped to you.
But before you do step 3, try step 1 first, because temporary red lights happen quite often, so just let it rest for a little while for now.
Dec 29, 2009 | Microsoft Xbox 360 Console
All four lights in the ring are red and flashing, the power light is green and not flashing.
the 4 red rings means that the av cable on your xbox cant be be detected, try to unplug it from the xbox and plug it back in. if that doesnt work if you have another xbox try hooking it up to that one, to see if you might have a bad cable. or try cleaning the metal part of the cable with a dry cloth. if nothing works i would do 1 of 2 things. 1. get a new av cable for the xbox, or 2 trying and get a replacement from microsoft.
May 03, 2009 | Video Game Consoles & Games
2 light flashing red lights once game is on for 5-10 min.
your xbox is overheating put it in an open area and let it cool overnight i might even suggest the nyko intercooler ex
Sep 26, 2008 | Microsoft Xbox 360 Console
My xbox has three blinking red lights and wont work
there is a common occurrence of total failure in Xbox 360 the 'red ring of death', where three of the red lights on the console flash, and the console locks up. there is a recall and repair for the failure that extends to 3 years from purchase, many xbox 360 have been repaired more than once under this plan, my son's has.
http://support.microsoft.com/kb/907534?sd=xbox
MS will not repair the xbox if it has been opened they will suggest that the failure is caused by any modification, take photographs of the console before placing it in the shipper MS will send you for the repair, they will damage it, you will need proof
do not attempt repair yourself,
http://service.xbox.com/servicehome.aspx
Jul 03, 2008 | Video Game Consoles & Games
This may sound weird, but if you cover the entire xbox in towls, making sure to cover all the exhast vents, turn it on, then wait 10-15min; when you unrap it, turn it on again and it should start up. Keep in mind that this is usually just a temporary fix.
Dec 31, 2007 | Microsoft Xbox 360 Console
ROL??
if you have 4 flashing red segments, then it's a graphic VGA lead problem, 3 flashing segments means a hardware failure.
If you are continually getting problems, return it to your retailer for an exchange as Microsoft guarantee the 360 for 12 months on hardware failure.
Oct 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
65 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
