Question about Casio Ctk 496 Electronic Keyboard with 61 Keys and Singalong Capability
Bought a sustain foot pedal and it works the opposite to what it is supposed to...have to release the pedal for the sustain effect
  • Casio Master
  • 5,603 Answers
Yep!!! Happens all the time and only a few synths have the option of selecting the operating mode.
NOW if you can open the pedal, USUALLY the switch has both the Normally Open and Normally Closed functions that a single wire can be moved to reverse the operation.
USUALLY you will need a soldering iron to make the change.
Posted on Nov 19, 2009
Hammond sk1 foot switch is set to toggle Leslie effect between fast and slow. How do I change it to act as damper sustain pedal or other function such as glide?
Thre is a sustain pedal jack next to the foot switch jack. The pedals used are different. The foot switch is a latching switch, the sustain pedal is a momentary.
Dec 29, 2016 | Hammond Music
Sustain pedal does not work
Yamaha FC4 and FC5 sustain pedals are normally closed, sorry Fred. Roland is opposite. I suspect the P120 just needs to be reinitialized. Hold down top white key (C) while turning on power. Wait 3 seconds and then release white key. Should now be reset to factory spec. Always plug the pedal in before you turn it on. If it still doesn't work check it with a meter.
Mar 17, 2012 | Yamaha CP300 Stage Digital Piano...
I have a Casio CDP 200R. I recently purchased a FC4 foot pedal but it works in the reverse way. I tried switching the piano off and then plugging it in and it still does not work. Can you please let me...
You should try having the pedal connected when you turn unit on. Some pedals can be rewired to act opposite... However I believe this pedal should work with the Casio. You can open the pedal and see if you can move one wire so it works opposite. Also verify that the jack is set to the "SUS" setting per your user manual... around page E14
Sep 07, 2011 | Yamaha FC4 Piano Style Sustain Pedal
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Fc4 sustain pedal is in "sustain" mode at all times -- it won't release the sustained notes. I tried plugging the pedal in (to a roland ep-9) before powering up and had the same problem.
Sorry, but the Yamaha pedal has the opposite sense (it is a normally open contact) than what is REQUIRED by Roland equipment. Roland requires a Normally Closed contact. Unfortunately, one is confused because the Roland jack for the sustain shorts itself to no sustain when you unplug a pedal. SOMETIMES one can open a pedal and with soldering iron change a wire to reverse the pedal sense IF the particular pedal has both contacts available.
Jun 16, 2011 | Yamaha FC4 Piano Style Sustain Pedal
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
When i press down on it it wont sustain but when i take me foot off the pedal it will sustain. fc5 yamaha
You may be trying to use this with a Roland synth... they require the OPPOSITE type switch.
If you have a Yamaha higher end product such as Tyros, there is a setup screen in the utility menus to set the polarity of the sustain and other inputs and that setting may be wrong.
Jan 14, 2011 | Yamaha Fc5 Sustain Footswitch
Hi, i purchased yamaha fc15 sustain pedal yesterday. when i connected this pedal to my Roland E-09 keyboard through foot switch port, it activate Start/Stop button ( of arranger & song controls ) and...
The answer is NO... Roland uses the opposite sense switches on foot pedals... They use NIRMALLY CLOSED and your Yamaha is a NORMALLY OPEN switch.
SOMETIMES you can open these pedals and find that the pedal has the opposite sense switch available and you only have to unsolder and move one wire to make it a NORMALLY CLOSED pedal.
Dec 24, 2010 | Yamaha Fc5 Sustain Footswitch
Sustain Pedal Opposite Effect
I found that if I plug in the sustain pedal BEFORE turning the power on, it works fine. If I plug in the sustain pedal AFTER turning the power on, then it works in the opposite way. Probably just the design. So I would try playing with that before doing anything drastic.
Feb 16, 2009 | Yamaha Full-Size Keyboard
Casio Ctk 496 Electronic Keyboard with 61 Keys and Singalong Capability Logo
206 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
