Question about OKI MICROLINE ML-395 Matrix Printer
Microswitch that detects out-of-paper seems to be working in reverse. With no paper loaded, depressing the switch gives an alarm. Release the switch and the printer will go online.
  • 446 Answers
If you have ever tried to disassemble the micro switch, chances are you might replace the connector the other way around, if not then the problem is the micro switch itself.
Posted on Nov 19, 2009
My royal sp12mx will work in reverse but nothing happens when i insert paper to shred. light is on
there is a very small lever between two cutters around the middle that activates a microswitch to turn it on when you offer paper to be cut
the problem will be in that area ( switch or lever broken) as it's purpose is to switch on the cutters
reverse is straight drive from the control switch
Aug 27, 2016 | Royal SP12MX 12 Sheets PP Security Plus...
Hp officejet 8500 premier printer has paper jam alarm,also I don't see paper being picked up from input tray at all
Hi........................
Please click here for solution :-
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP 8500 Premier All-In-One InkJet Printer
My office Max OM01287 Shredder will only run in reverse. There appeared to be a jam in the cutters and with tiny tools and very careful grabbing I seem to have cleared the jam from tiny pieces of paper. ...
There is still a shred of paper jamming the microswitch that sets the shredder into reverse to avoid an even worse jam. Find that microswitch, usual;ly on the left or right side, activated by a plastic flap on the basket side of the shredder. Clear it. As you move the plastic flap up and down you should hear it click. No click, the switch is jammed.
Mar 12, 2011 | OfficeMax Office Equipment & Supplies
Ready and alarm lights keep blinking. will not print
Service manual: ready and alarm blinking :
Paper Jam
Clear the paper jam and press the panel button if the printer
does not automatically resume printing.
Misfeed:
Re-install the paper and press the panel button.
Clear the jammed paper inside the printer. Press the panel button
if the printer does not automatically resume printing.
check the sensors:
1) Turn off the printer power switch, open the front cover, and remove the drum unit.
2) Turn on the printer while pressing the control panel button. The Drum LED comes ON.
3) Lightly press the panel button again.
Alarm LED is ON = Front registration sensor is turned ON.
4) Press and release the panel button again.
Drum LED is ON = Paper eject sensor is turned ON.
If sensors are On, paper is being detected, Off- no paper
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 21, 2011 | Brother HL 1240 Printer
My printer says there is no paper but there is and when i restart it it senses there is paper and trys to print i get a loud clicking sound and than it reads no paper
The paper is not feeding from the paper tray. The load bang is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play. If the rear guide is tight, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, but will see calibration marks for the paper size you are using. Unlock the read paper guide n the tray, squeeze the release and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Nov 16, 2010 | Brother MFC-8860DN Printer
Dyson cr01 outer door not locking, after pressing start, showing(lock outer doror, then press star)i am tring but same msg again
This solution worked for me, but there could well be different problems which give the same sympoms. My problem was that the microswitch had become worn with use and the interlock slide would no longer cause the switch button to depress but rather it was trying to push the button sideways.
Remove the 2 screws from the rear of the lid and daw the lid off by sliding backwards then upwards.
Remove the 2 torx screws from the top of the front panel that have now been revealed.
Carefully prise the front panel upwards only on the door lock side until the front panel comes forward giving you access to the interlock mechanism.
Remove the 2 torx screws from the front panel holding the actuator in place and remove the interlock mechanism from behind the front panel, disconnecting the two spade connectors and the door release strip.
Carefully prise the two sections of the actuator apart using a small screwdriver in the slots at either end
You will now see two microswitches connected together by a short wire link.these switches are activated by grey plastic slides, one of which slides when the door catch is engaged in the interlock, the other slides when the first one has been actuated and the solenoid actuates. In my case the first one was worn and was jamming the switch instead of pressing it in.
Remove the two microswitches by prising one off its locating pins and lifting it up then prising the other off its locating pins.
There are 2 very small locking tabs on the switch. Prise them out slightly then the switch side can be lifted off.
Slide out the switch button, rotate it through 180 degrees and place back into the switch. This means that there will be a new face in contact with the actuator slide. Hopeully this will provide another few years of good service.
Rebuild by reversing the previouse steps.
Nov 08, 2010 | Dyson Memory CRO1 Front Load Washer
Why does the paper light keep blinking even though paper is loaded correctly in the tray?
Check the microswitch inside the printer paper tray. Turn off the printer first and unplug it. There is a sensor switch that may need cleaning from paper dust, or the microswitch that tells the printer there is paper there may be bent, good luck
Jul 11, 2010 | Brother HL-2040 Laser Printer
Old Rexel 1250 - falsely detecting safety cover is open
You'll have to unplug the machine, then remove the screws front (inside door or cabinet) and rear to remove the top cover. Insure that the safety cover arm which contacts the microswitch is not broken or the microswitch is out of adjustment.
Oct 24, 2008 | Office Equipment & Supplies
Unlocked tapes recognized as locked
this is probably due to a stuck microswitch in the tape drive unit as the locked tag presses a microswitch when loaded it is possibly these microswitches that are failing, as one of the switches detects if a tape is loaded and the other detects is a tape is locked, so problems with these switches would mean that it cannot detect if the tape is loaded properly.
Sep 30, 2008 | Sony DDS SDT-D11000/ME DAT Tape Drive
Printer error 1003
Bought an Epson printer. Cheaper than a repair
Jun 11, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
OKI MICROLINE  ML-395 Matrix Printer Logo
185 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
