Question about Weather King 10AJA2501AH Air Conditioner
Can I add an after market heat strip kit to my GE window A/C? If so where can I get one?
  • 3,361 Answers
The answer is NO.
You would also have to change out the thermostat and control switches. If this is a board controlled unit the board would have to be changed too.
Posted on Nov 21, 2009
I have a fedders window unit 220v 18000btu. The ac side works great but when swapped to heat it just blows cool no heat. The filter light starts flashing as well in heat mode
Those window units usually have a strip heat kit that supplies the heat. You might want to have a technician open up and check heating circuit.
Oct 31, 2014 | Heating & Cooling
Remove
Original equipment rear auto glass is not designed to have the "heating element" removed...these lines are imbedded into the glass during production. If your current rear defogger is not working, you have a few options. You can replace the entire rear glass (very costly), you can add a new aftermarket defogger strip and connect to original equipment wiring...(maybe to many lines for your viewing...or you can add a rear blower motor vent to the rear shelf...(most effective, aftermarket kits are vailable, probably your best choice to address a need for a rear window defogger. Hope this helps.
May 02, 2013 | Cars & Trucks
The water dispense not work ice is good.
Check water line from bottom of freezer door open line if you have water there when activating water arm then you have frozzen water line in door common GE problem need heat strip added in side door GE has a kit for that
if there is no water at door then replace water valve in back of ref bottom under cover freezer side
Jan 30, 2013 | Refrigerators
Whirlpool top freezer mod#et1ftkxkq00 which when frezer gose into evaporation mode water drips threw square insets into refrig. compartment,a friend has same problem.What do i do to correct this? I was...
HI, Unplug the refrigerator. First thing you do is remove the floor panel of the freezer. Do you see ice?
If there is ice, remove the rear wall of the freezer as well and start removing the ice. There will be down inside the drain hole also. A hair dryer works great for this project.
Please do not use sharp object/tools.
Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add. Part# 819043
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Refrigerators
Whirlpool refrigerator leaks inside
HI, First thing you do is remove the floor panel of the freezer. Do you see ice?
Please let me know if I can help you. I have the kit on my web site www.whirlpoolpartssurplus.com
Thanks
Vic
Jun 20, 2009 | Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water collects in bottom of refrigerator
Thanks
Vic
May 23, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water accumulating in the bottm of refridgerator
HI, Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add.
Let me know if I can assist you
Thanks
Vic
May 17, 2009 | Refrigerators
Zoneline Airconditioning - Winterizing and drain line
Yes this will recycle the room and can be cover outside if it is not a heat pump and will use elec heat strips to heat. As long as it is tilled toward the back the water will run out the back without a drain kit there should also be a drain hole in the bottom.
Oct 06, 2008 | GE Heating & Cooling
Weather King 10AJA2501AH Air Conditioner Logo
55 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
