Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
TI 84 Won't turn back on
I went into the application Francais and the screen showed up but when I tried to exit out of the application it would not let me. When I pushed the 2nd button I saw a 6 appear on the top right hand side of the screen. When I pushed the down arrow I saw the number 4. I did this several more times until the number was down to 1. When I pushed the down arrow again, the calculator completely shut off. I've tried to connect to the computer and to another calculator to turn it on but it won't do anything. I've manually restarted it and it still won't work. Will you help me?
  • vin__L Sep 06, 2008
    My son's TI 84 Plus won't turn on. Thought it was dead batteries and replaced the AAA's still nothing. I then replaced the lithium battery still nothing. I tried the procedures on the TI web site to no avail. When I remove all batteries and reinstall after a few minuted I get power and operation but then it won't shut off. As far as I know he has no funky programs loaded.
  • Anonymous Oct 28, 2008
    The piece of junk broke brightness went to 0 wont turn on for $120 a calculator should break so easy what a piece of junk it needs a fix that wont let you go past 1 brightness so you can raise it back.
Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL, reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Posted on May 18, 2008
  • stfleurmoura
    stfleurmoura Jan 27, 2012
    you are the smartest person ever!!!! u fixed my dumb calculator...now if you could only explain why this happened
  • stfleurmoura
    I love you, ur a geneous
  • 4 Answers
I believe your problem is actually your screen brightness, try this key combo [ON] [2nd] [UP], and HOLD IN UP. this should adjust the screen brightness back up and you should stop near 5. If you go above the desired level (screen becomes too dark) use the key combo [2nd] [DOWN] until you return to the desired brightness
Posted on Feb 22, 2008
You have made the lettering so light that you cant see it anymore. What you need to do is press the second key (then let go) and then hold dowm the up arrow until the numbers on the screen become dark enough for you to see them. You will see numbers flash in the top right corner, but they're just telling you how dark/light the numbers on the screen will appear. The normal setting is 5.
Posted on Feb 05, 2009
  • 58 Answers
Take out all the batteries including the lithium one, and wait a minute... reinsert the batteries and immediately remove the francaise program (it's a waste of space anyway)
I would also suggest updating the OS on the calc because I think that bug was fixed in an update... I don't know though... I never used that program.
Good Luck
-Saik0Shinigami
Posted on Feb 08, 2008
You adjusted the contrast on the screen.
To fix it just push the 2nd button and then the up arrow until you can read the screen.
Posted on Oct 10, 2008
Uninstall the ti connector kit and then restart your computer and later reinstalll the ti connector.
Posted on Sep 01, 2009
Press 2nd key relase and press the up arrow key atlist 6 times
Posted on Oct 27, 2010
    New Friend:
    Problem Solver:
  • 10 Answers
Mine was a rechargeable and it would not recharge. I pushed the tiny reset button on the back with a small pin. It now recharges but the memory was wiped.
Posted on Oct 19, 2013
Change the language on ti-84 plus silver edition
Press the APPS key. In the list of apps you should see one or more language names (Deutsch, Espanol, Francais, etc). If you want one of them, pick it. Else pick any one of them by pressing the number or letter in front of the name. In either case, you'll see a screen offering a choice between English and that language. Make your selection.
Apr 17, 2014 | Texas Instruments TI-84 Plus Silver...
Where is the reset button on a TI-84
Instructions
Enter the memory options by selecting "Mem." Press the "2nd" key followed by the "+" key. Select "Reset" from the memory choices. Use the arrow key to select and delete all memory.
After choosing to delete all memory, select "Reset." After this reset, your screen should show "Mem Cleared." Once you have reached this screen, press "Enter." If you installed programs or applications, you may need to remove them manually. Once again, enter the "Mem" command.
Press "2" to select Memory Management. If you are deleting programs, input that option from the subsequent menu choices. If you need to remove applications, input that choice and press "Enter. Select the application or program from the list displayed. Press "Del" to request the deletion. Choose "Yes" to confirm your choice.
Repeat this process to delete remaining programs manually. After completing this, exit the memory menu and press the "Apps" button. Make sure no applications remain. Additionally, press the "Prgm" button, and check that all programs have been removed
Aug 29, 2012 | Texas Instruments TI-84 Plus Silver...
Calculator messages are in french. We don't know how to change it to english
Press APPS. Select any of the languages (Espanol, Francais, etc). Select English at the sign-on screen. Press any key at the prompt to exit.
Nov 09, 2011 | Texas Instruments TI-84 Plus Calculator
I like to change back to english
Press the APPS key. Select any of the language apps (Deutsch, Francais, etc) and press ENTER. The opening screen will give you the choice of that language and English. Choose English and press ENTER. Press ENTER again to exit the app.
Apr 21, 2011 | Texas Instruments TI-84 Plus Silver...
My problem is the same as this previous post! "my ti 84 plus silver edition seems to be on a different language setting because i dont understand anything it says. what do i do to change it back to...
Press the [APPS] button. Use arrow to scroll down along the list of apps. Look for apps that have names of languages (Francais, Espanol, Deutch, Dansk, Italiano, Norsk, any european language whose name you can recognize). Once you find the name of a language, highlight it and press ENTER. In the screen that is displayed inviting you to select a language, press 2:English. and press ENTER. The calculator localization should change to the default English language.
To avoid having to do that again, and to save memory spsce, delete the language apps you do not need. delete also the applications that are in those languages (periodic table, Cell Sheets, Science Tools, etc.
Mar 12, 2011 | Texas Instruments TI-84 Plus Silver...
How do I change the language back to english
Press the APPS key. Select any of the language apps (Francais, Deutsch, etc). The opening screen will give you the choice between that language and English. Select English.
Jan 07, 2011 | Texas Instruments TI-84 Plus Silver...
How do I change the language from German to English
Well you may please follow the steps below to change the language to English on TI-84 Plus -
• Press the [APPS] key.
• Under the applications listed select the language currently on the calculator (For example Francais, Espanol, Dutch...) and press [ENTER].
• On the Language Localization screen, the choice to select a language is given. Select English and press [ENTER].
Good Luck!!
Thanks for using FixYa!!
Aug 20, 2010 | Texas Instruments TI-84 Plus Silver...
Ran out of coding room on my TI-84 PLUS
if you are out of memory try deleting some applications (or backing them up on your computer).
If you cannot see your (function? ) plots check the window dimensions.
Hope it helps.
May 21, 2009 | Texas Instruments TI-84 Plus Calculator
TI 84 cant turn on
Sounds like your pc had a static charge that it discharged to your TI and that it fried something inside the TI. No warranty, No fix. You gotta buy a new one.
Apr 10, 2008 | Texas Instruments TI-84 Plus Silver...
How to restore applications on TI-84 Plus Calculator
THIS WILL HELP YOU 4 SHO
the best way to get all your applications back is to link your friend's ti-84 plus and make a file backup, ( do this by first installing Ti graphing Product CD wich is included with the calculator) after this just connect your calculator and store the files back onto your calculator! ZOMG??? IS it that easy???
yes it is, just apply some clear thinking and ull be just as smart as i am
Mar 23, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
10,226 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
