Question about Panasonic PT-53WX54 53" Rear Projection HDTV
My pt47x54j went black during a movie. Light flashes 3 times indicating a power source problem, any idea of the repair.
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
YES, three blinks is error code for short protection. 98% of the time in this model it means one or both of the two STK-392-110 convergence chips is bad.
There is a easy way for you to confirm this. With the set unplugged remove the back cover. The two chips are 2 1/2 X 1 1/2 inches and black in color--they will have the STK-392-110 PRINTED ON THE FRONT OF THEM IN WHITE LETTERS.
They will be on Metal heat sinks with fins side by side.
What you want to look at is there are about a dozen light blue resistors around them--most will be marked 2.2 ohms.
Look carefully at the resistors--if even one is discolored or somewhat white in the middle you have found your problem.
They can be tested just like testing a fuse--should show as a short if you measure across them.
This repair involves replacing both chips and any bad 2.2 ohm resistors.
I have START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET.
If you have some skill at soldering etc--the instructions will tell you everything you need and how to do the fix yourself.
Most shops are going to get 300 or more for this repair and some will not do it in the home.
You can buy a pair of the chips on Ebay (I can tell you the seller there I buy from) for about 12 dollars plus shipping---I have repaired hundreds of these sets--it takes about a hour or so.
Let me know if you want the instructions and I will post them here---
If this information has helped you rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 19, 2009
  • 8 more comments
  • bsfry59 Sep 26, 2010
    Can you post the instructions or send them to me. Also the buyer you use on ebay?
  • SD Tech
    SD Tech Sep 26, 2010
    Yes to both questions---post a email and I will follow up
  • CondorDad Sep 30, 2010
    WHAT IF THERE IS NO SIGNS OF THE RESISTORS IN WHITE CAN IT BE JUST THE CONVERGENCE CHIP?
    Never mind I found the white resistor. Can I get the instructions to replace it?
  • SD Tech
    SD Tech Sep 30, 2010
    To last person who posted here. You are not the person who posted the original question.
    I am in California. Post real question Attention SD tech and I will help.
    SD TECH
  • leecollinslt Oct 21, 2010
    Pls send instructions. Jeff
  • deldershaw Oct 22, 2010
    Can you please email these instructions to dave.eldershaw@gmail.com.
    I seem to be having the same issue.
    Thanks
    hello, can you please email me the instructions to dave.eldershaw@gmail.com.
    thanks
  • SD Tech
    SD Tech Oct 22, 2010
    Fixya does not work in this way. I am happy you liked the solution but what you need to do is post a question of your own, you can in the title mark it ATTENTION SD TECH and if I see it, (I am in California) I will be glad to help you.
    You have several choices--you can post it in the free section or there are several levels where you pay for an answer, in the free sections some experts will bid on this to get you to decide if you want to pay or want a free answer.
    There are rules here which do not want help given to someone who did not actually post the question.
    SD TECH
  • Rich261 Jan 11, 2011
    Hello SD Tech, I am having the same problem and would like to request the instructions as well as the Ebay seller. Thank you very much for your help.
I have a vizio tv that went off during a movie. When I hit the power button it blinks white once and nothing happens. Can I fix it?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 22, 2017 | Vizio Televison & Video
My LG 47LA6200-UA just went out. Turning on it flashes and goes black. Red light flashes 3 times. Flashlight shows picture, audio works. Is this the LED strips or something else? Thanks for any help!
If blinks continue without any pause, the main board is faulty.
Dec 25, 2016 | LG 47LA6200
What is causing the black screen and 3 blink light?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 16, 2014 | Panasonic VIERA TC-P60GT50 60-Inch 1080p...
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Every time I start the machine the f1 error comes up within a few seconds. have to press pause & start about 3 times & it will finally start to work. have to do this several times during the entire...
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^@#$%
Jun 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Hitachi Projection power shutdown??
Possible convergence chip bad.--'3-D color vision'.
Apr 17, 2010 | Hitachi 51F59 51" HDTV Projection...
TV screen is black. Was working went black and now nothing.
you have a bad capacitor in the power board you will need a tech to change it the can shaped device will be puffed up on the top and the value is written on the side
Dec 04, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
No power
I was watching a dvd and during the movie the screen went black and shut down. Now it won't start at all
Jun 13, 2009 | Computers & Internet
I have a Sony KP-53HS10 TV. The screen just died. There is a red light in the front that flashes, any idea on what to do? Thanks!!
this happened to us about 3 months ago. We were in the middle of a movie and the screen went black, red light flashing. we went online and the lamp bulb is blown. you can order a new on online, cheaper than Sony will charge you.
Apr 04, 2009 | Sony KP-53HS10 TV
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
292 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
