Question about Frigidaire PLHS269ZC Side by Side Refrigerator
At times my frigidare plhs268zcb1 compressor is working at times it not. I had a repair man at the hous who thinks the compressor is gone. If its gone why would it eventually come back on and start frezzing again. Is it shot and should i even put a new compressor in or could it be something else? Thanks
  • 4,059 Answers
I would suspect the compressor starter/overload relay first. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Nov 19, 2009
Frigidare chest freezer model cf-8h-L compressor is running but not getting cold on the inside
Recycle it. It is on R12 which we haven't used for 20 years. If the compressor has gone, or if you have lost all the gas, it is beyond economic repair.
Jul 13, 2015 | Freezers
My 13 yr old frigidare refrigerator quit freezing in freezer and getting cold in bottom part. Fans, light still run.
You're looking at the end of the life expectancy for a refrigerator. The unit's compressor system, which forces the coolant through the coil system, is driven by a capacitor-type motor. Before doing any work on a refrigerator or freezer, make sure it's unplugged. After unplugging the unit, check to see if the motor/compressor has a capacitor; this component is located in a housing on the top of the motor. Capacitors store electricity, even when the power to the unit is turned off. Before you do any work on a capacitor-type refrigerator or freezer, you must discharge the capacitor, or you could receive a severe shock. Most likely this capacitor has gone.
Oct 10, 2012 | Frigidaire Refrigerators
My broiler works on my frigidare oven but the stove will not light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 26, 2010 | Frigidaire FGB24S5A Gas Single Oven
Compressor is not turning on. anything I can check before i call a repair man?
Yes, your overload relays have gone bad at the compressor. Install new overload kit and you will be fine.Hope this helped.
Feb 02, 2010 | Whirlpool ED5GHGXMQ Side by Side...
Air conditioner compressor clutch not dropping out, clutch engaged all the time? Drives cabin freezing up.
wow, sen me this truck man, lol. that compressor putting out. ok fun an joke aside. the termostat and the ac pressure switch is gone, replace and system will work normal
Nov 13, 2009 | 2004 Ford F250
Fridge not blowing cold, Buzzing inside black ball "compressor"
The black ball you are reffering to is the compressor.It is trying to start..that is the buzzing.The start,and overload relay is probably bad..hopefully.Because if it isn't the compressor may be bad.Where your wires plug into the compressor...this is the relay.it should come off fairly easy.It is much cheaper to replace this part..than buying a new fridge.For instance i buy them for g.e. refrigerators all the time from an appliance repair shop at cost,and they are less than 4 dollars for me.So I assume they aren't too expensive retail.
May 17, 2009 | Frigidaire FRS23R4A Side by Side...
My house have a gas heating and electric cooling system. When I turned the cooling on the outside fun started but the cooling system inside house does nto start. I tried heating system it dose not start...
if the fan outside is running then feel the compressor outside or listen to it if you can notice that the compressor is running the same time the outside fan is running also.
it could be that the compressor is not running.
but if you can notice that the compressor is making a different sound as it turn on, then the compressor is running but not cooling, then you could have a leak problem. there is no or little refrigerant in the system.
if you have a leak, please contact your local repair man to do it.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Heating & Cooling
We have a Frigidare S3BA-036KA split condenser with a badly rusted Compressor run capacitor. What is the correct capacitor for this unit?
I Had a similar problem with my Air Conditioning unit, the repair man said without the information their was nothing he could do, but that he would go look for it.
This is what i was able to find, This litterally all just took place within the past hour so i don't know if its workable information, but here is my two and a half cents.
http://www.transtaracsupply.com/pdf/s3ba.pdf
Aug 08, 2008 | Frigidaire Heating & Cooling
Freezer not working
compressor is faulty. clicking noise you hear is the overload for the compressor. not worth repair and not diy
Mar 18, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire PLHS269ZC Side by Side Refrigerator Logo
137 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
