Question about E-Machines eMachines Desktop PC
How do fix the corrupt drivers to get the codes back?
EMACHINE 6419 CD/DVD Drive is Corrupt or Missing (Error Codes 10, 19, 31, 32, 39, 41)
    President:
  • 1,257 Answers
    Champion:
  • 206 Answers
Uninstall that driver, and chipset drivers, and then let your machine to load the drivers it self
Posted on Nov 19, 2009
    President:
  • 1,566 Answers
This article might help you in fixing the error code 19. I have tested this one and it worked for me. The error means that the optical driver got corrupted.
Microsoft Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this imagehow do fix  the corrupt drivers to get the codes b - vistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. Collapse this imageExpand this imagesecurityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Microsoft Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Posted on Nov 27, 2009
MY EMACHINE T3306 is saying cd/dvd isnt present in my system. Im trying install windows vista. need help!!!!!
This could be due to a missing or corrupt driver. To verify (assuming you are using XP), right click "My Computer" select "Manage". On the left-hand side of the window, select "Device Manager". Check tosee if your installed device or any device for that matter is located under the heading CD/DVD drives. If there are no entries and you do have a CD/DVD drive installed on the computer, try restarting to see if it will reinstall the device. If this does not work, the drive may not be connected or is bad. Turn off the computer, open the computer and you will see a ribbon cable coming out of the back of the drive. Verify that this cable is plugged into both the drive and motherboard securely (the slots will look like long, slim rectangular boxes with tiny metal rods standing up inside of them). If the drive is securely connected and the machine does not see the device when turned on, the drive is probably bad. If the device manager does have an entry for the drive and there is a question mark next to it, this means the driver for the drive is missing or corrupt. I have checked the emachines website and they do not have drivers for CD/DVD drive for your model. You will have to check the drives manufacturer's website to see if they have a driver for you drive.
May 12, 2011 | E-Machines emachines (emachinees) CD-ROM...
Got an error code 39 on my laptop what does it mean
error code 39 is:
Windows cannot load the driver
The driver might be corrupt or missing
suggests re-installing correct drivers
Sep 12, 2010 | Toshiba Computers & Internet
Error Code 39 for NG3046P HKW136D SCSI CdRom Device. "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
goto my computer and right click, enter properties and find deice manager click on the (+) sign on dvd/cd rom drives, right click on update driver, use the internet once option and see if it finds an updated driver, if this dosent work reply to this post, good luck.
Aug 12, 2010 | Dell Inspiron 1525 Laptop
DVD driver is corrupt and can not access my DVD
(Windows 7 CD-ROM Drive & Mitsumi CD-ROM Drive)Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Aug 10, 2010 | Fujitsu Siemens Computers & Internet
My DVD rom drive is not working I cannot "see" it on the system I have this error message "windowns cannot load the device driver for this hardware. the driver can be corrupted or m missing error code 29...
Check in device manager. To do this. 1st right click my computer, 2nd Click properties, 3rd click hardware, 4th click Device manager, 5th check that the computer is seeing the DVD/CD-ROM drives by double clicking the DVD/CD-ROM drives words or click the + symbol next to DVD/CD-ROM drives, the drop down menu will list your device if it’s there. If a device is listed double click the device. If it says it’s working properly click driver in the top bar and uninstall, then re-boot, the system will re-load the driver on re-booting. If the driver was corrupt it will re-install it correctly.
If the system cannot find the driver on re-booting it's missing from the systems file, go to the Support Fujitsu site and download and install the driver. Its free all you have to do is put the laptop details in the appropriate boxes and all the drivers for that laptop will be listed.
From your description of the error message it’s no doubt a corrupt or missing driver.
Hope this helps.
Feb 24, 2010 | Compaq Presario V4000 Notebook
Error 39, corrupt DVD/CD-Rom Drive
This has been a common windows issue. I'm sure that this will solve your problem. You can go to this link, http://tinyurl.com/toshibadvd, download the registry file and run it. After that, just restart your computer and it should be good to go.
If you're not sure and is worried about security since this is messing with the registry, you can just click on this microsoft link where it explains and gives you detailed instructions on how to manually edit the registry and fix the problem. http://support.microsoft.com/kb/929461.
This is typically the same thing, the first one is just a shortcut on how to do it. Just a reminder, EDIT THE REGISTRY AT YOUR OWN RISK!!!
Mar 30, 2008 | Toshiba Satellite A205-S4617 Notebook
E-Machines eMachines Desktop PC Logo
131 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
