Question about Acer Aspire 5315 Notebook
Cd rom my cd rom door wont open without picking it open and is it replacable?
  • 558 Answers
Yes it is you should be able to purchase one of the website.
Posted on Nov 19, 2009
I emachine dvd rom/burner won't open how can i open it? but before it really do not play any dvd and then now it wont open.
If the door on your CD/DVD drive will not open when you push the eject button (on the front of the drive), Click on Start, My Computer, and Right Click on your CD/DVD drive. Then Click on Eject. If the door still refuses to open, you can insert a paper clip into the small hole on the faceplate of the drive and push it in until the door opens. If the door continues to refuse to open in the normal manner, you will have to replace the drive,
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Apr 05, 2011 | E-Machines emachines (emachinees) CD-ROM...
The door wont open
Hold the button down without releasing it until the drive opens. If it still does not open, get a pin and look for the tiny hole on the face plate of the drive and press and hold it in to reset the drive.
Nov 14, 2010 | Sony (CRX320AE/U) CD-RW/DVD-ROM (Combo)...
CD in stuck in the computer and I can't get it out using the eject button. How do I get it to come out?
hi,
its too simple. you dont need to worry.. Check the front side of the CD ROM. you will find there one small hole. Now just take a thing, which is around the 4 to 6 inch (min is 4") long and can pass through that hole (for eg. take medium size U pin, and remove all bends and make it straight or long needle) Now insert this equipment in that hole and press. your ROM will eject...
Hope this has helped you ... Thanks....
Jul 19, 2010 | Computers & Internet
Cd rom door wont open
Do you see blinking light on your CD Drive. If not, you may need to check you power supply to CD Drive.
If yes, may be door looks jam, opening up once may remove any dust to smooth it out again. To open up there is small pin hole on cd drive, generally on the right side, use needle and press it through the pin hole, it will eject the CD Door and you can pull it out completely.
May 13, 2010 | Computers & Internet
Cd wont eject acerdesktop
look closely at the front side of the cd-rom, you will find a very tiny hole at the cd-rom door, used a hiar pin or an any wire that can go inside the hole and press it good to make the door open.
Dec 28, 2009 | Computers & Internet
My dvd and cd rom does not pick up dvd but only cd's
Is it really a DVD drive? DVD drives can pick both with ease but a CD drive cannot pick DVD's.
Nov 29, 2009 | Acer TravelMate 512DX Notebook
Cd rom drive door
Best guess is that a small plastic catch broke. My cousin has similar doors on his CD trays. I personally would take the doors off. As far as repair, again best guess without seeing it, is that you'll need a new door panel.
Feb 20, 2009 | HP GX613AA Pavilion A6300F Desktop PC
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
The cd-rom door not open
Sir,
You have encountered a problem often seeen in LG models. It could have spontaneously generated or as a sideeffect of recent servicing. It is difficult to correct. so an alternative way is use a pin to force open the door.
On the front panel there will be a small mm hole through which insert a straightened paper slip to force eject the door. once door is out a little. pull it or use button to fully take out the tray.
For future, always keep a cd rom inside. that will probably let you eject the tray automatically. Problem occurs usually only withthe empty tray. good luck
Dec 04, 2007 | LG (CRD-8400CB) CD-ROM Drive
CD Rom Driver door won't open without using the straightened out paper clip or pressing the driver door button upwards of 15, 20 or maybe 25 times. It will eventually open after repeatedly pressing for...
If this happens with all your CDs and everytime, I would suggest you should replace your CD Rom Drive with a new one. After use of some years CD Rom Drives have such problems. Otherwise a software might locking your drive. you should find a tool which unlocks the drive and then press the eject button.
Oct 06, 2007 | Acer Aspire M1640 Refurbished Intel...
Acer Aspire 5315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
