Question about Motorola Mobility RAZR V3
The screen lights up but, no display. phone beeps when keys are pressed and turns off.
2 short beeps pause 3 short beeps
NUMBER LOCK
You have press the NumLk key (number lock) and this changesthe right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock).it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicatethis function has been selected.Press the NumLkkey again to turn off the Number Lock.
Jul 11, 2012 | Toshiba Satellite Computers & Internet
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
How To turn on the headset bloothoot nokia model bh212
Switch on or off
To switch on, press and hold the
multifunction key for about 2 seconds.
The headset beeps, and the green
indicator light is displayed. The
headset tries to connect to a paired
phone.
To switch off, press and hold the
multifunction key for about 5 seconds.
The headset beeps, and the red
indicator light is briefly displayed.
Pair the headset
1. Ensure that your phone is on and
the headset is off.
2. Press and hold the multifunction
key (for about 5 seconds) until the
green indicator light starts to flash
quickly.
3. Activate the Bluetooth feature on
the phone, and set it to search for
Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair
and connect the headset to your
phone. In some phones, you may
need to make the connection
separately after pairing.
If the pairing is successful, the
headset appears in the phone menu
where you can view the currently
paired Bluetooth devices.
When the headset is connected to
your phone and is ready for use, the
green indicator light flashes slowly
Mar 26, 2011 | Nokia BH-212 Bluetooth Headset
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
Mar 07, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
I have a toshiba estudio 200l wuth perform preventive maintenance on display. How do I clear off of screen?
turn off power
hold down 0 & 8 keys
turn power on with keys still held down till beep is heard
enter 252 then press start key
enter 0
press enter icon on display
power off & on
should clear service message
Feb 15, 2010 | Toshiba Office Equipment & Supplies
When I turn on my laptop it goes on but the screen is black and it seems locked up. Tried control, alt, delete and turning off and on but nothing works.
in stead of alt crtl del try pressing F8 key on keyboard after you turn it on, it will display a few options. go from thee.
in case it does not stars, you may have a faulty memory ram. it needs to be replaced
Oct 07, 2009 | Computers & Internet
I have a dell inspiration 1100 and last night I was reinstalling Windows XP and all the drivers after installing the system drivers I got a diag>: I didn't know what promt to put in here so I shut the...
Since you have power on your laptop. I have this questions you need to answer: 1. have you seen Dell logo after turning on the computer? 2. After turning on the computer heard beeps? If all no do this
1. Turn off laptop remove batt and use ac adapter
2. While laptop is off press Fn key + Power button to run test check if you see display test in progress. If no, wait for 5 minutes to listen to beep codes. Once heard beeps keep pressing hold on N key. If fails turn off laptop
3. While laptop is off, press hold D key + power button. Check if you will see colors display whole screen. If no this will need to replace LCD call Dell.
If see colors whole screen replace motherboard call dell.
Oct 01, 2009 | Dell Inspiron 1100 Notebook
Samsung SGH-D880. Cannot turn off annoying beep
Key tone volume
In Idle mode, press [Volume] to adjust the key tone volume.
You cannot adjust the key tone volume in any other way.....
Please rate this solution
Jun 09, 2009 | Samsung Cell Phones
Phone has no display and turns off when I press any key
You should take teh phone to a mobile service center and have them flash the firmware on the phone..to correct the issue.
Nov 11, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Ptc-701
Try these steps to correct the problem...
  1. Turn the Telxon off
  2. Hold down <space>, <enter>, and turn the Telxon on
  3. 42> will display
  4. Hold the 5 key down for three beeps. The unit will go blank for about one minute.
  5. Display will read "MEM OK"
  6. Turn the Telxon off and wait about one minute
  7. Turn the Telxon back on
  8. 42> will display again
  9. Press the 6 key on the Telxon
  10. "TP_" will display
  11. Press 58 and then <enter>
  12. Hold the 3 key down for three beeps
Aug 12, 2008 | Symbol PTC 701 Portable Terminal
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
