Question about Kirby Heritage II Vacuum
Kirby heritage model 1hd. wires fell off safety switch. Need color to position on switch
  • 36 Answers
If your looking at the back of the switch were the wires go in. Starting from left to right. you will see letter below the hole were the wires go in. for example, Y , yellow or " R " for red. this should help.
Posted on Nov 20, 2009
Do the Gsix and Ultimate G Kerby bags fit on the heritage II
yes this fits, kirby now have a universal bag to fit all models see kirby.com
Feb 19, 2013 | Kirby Heritage II Vacuum
Motor light comes on but motor does not start on Kirby Heritage II
Remember that the motor will not run unless the vacuum head or hose are properly installed. If this is not the problem, the most likely problem is that the carbon brushes in the motor are badly worn and will need replacement. A less likely problem is that the front safety switch is out of adjustment. While the light is on, remove the head and push the metal rod on the switch next to the fan inward to see if this causes the motor to run.
Jul 06, 2011 | Kirby Heritage II Vacuum
I shampooed my carpet and later that day went to use the Kirby Sentria and it wont turn on... it has always worked fine up to this moment, what could be wrong?
there is a safety feature on the kirby that if there are no attachments on the front or the side it will not turn on. check and make sure your attachments are properly on the machine
Apr 21, 2009 | Kirby Heritage II Vacuum
Using accessories on a Kirby Heritage 84
my guess with your kirby is the safety switch on the right side of your vacuum is not being pressed down, are you sure you have the right model of hose? any Heritage 1 2 or Legend 2 can work with it since they all have the same switch. your carpet head is working from the sound of it so either it's just that the high speed switch (being pressed fully down) doesn't work or you are not using the right type of hose (or the piece that engages the switch could be broken off
Oct 09, 2008 | Kirby Heritage II Vacuum
How to replace a fuse a Kirby Ultimate G Series
There is no fuse in the Kirby. There are few things that you want to check:
1. Cord - most likely cause. It may not be damaged but wires inside may have snapped if it got between doors.
2. Safety switch inside - no easy way to check. We usually just put a new one in and see if it solves the problem.
3. Motor - very unlikely that something is wrong with the motor - those are very hard to kill.
Apr 20, 2008 | Kirby Heritage II Vacuum
Fuse for Kirby vacuum
I would take it into a local vacuum shop but DONT take it to a kirby shop because they will charge way more
Apr 13, 2008 | Kirby Heritage II Vacuum
Kirby heritage 2 sweeper
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
the above link shows you how to change the belt on the g-series kirbys but it will apply to the heritage edition as well...the only difference is the color...some of the arrows may be missing on the front belt lifter knob...but they are little differences...
hope this helps!!!
Feb 06, 2008 | Kirby Heritage II Vacuum
Kirby Heritage II not starting
take the cover off to get to the wiring and check the brushes - that is where the clear-insulated black & green wires terminate at the motor sides under the plastic caps
Nov 20, 2007 | Kirby Heritage II Vacuum
Vacuums Logo
141 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
