Question about KitchenAid Refrigerators
My fride is leaking water from the bottom - KitchenAid Refrigerators
  • 4,059 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Posted on Nov 19, 2009
Fridge freezer warm 2touch on outside and water lying in bottom of fride
1. Defrost timer failed, check to see if it is running at all over a half hour. If not, look into the defrost timer. This also drives a heater around the door.
2. Door not closing fully.
Aug 03, 2014 | CDA GENUINE Refrigerator Fridge Freezer...
ITS NOT KEEPING FOOD COOL......LEAKING WATER FROM LEFT AND RIGHT SIDE. ICE CREAM MELTING
The model is not mentioned but I think that the fridge is defrosting from the evaporator to leak the water out.
Set your thermostat to normal and see if the fridge is cutting off when the ice forms.
If not switch off fride fully for about 6 hours and start again . If cooling is good then check for auto defrost timer, the thermostat or poor lining of the gasket .. faulty gaskets.
If food is not cooling then check on gas pressure, pumping of comrpessor., if poor reading change gas or overhaul compressor.
Estimate and decide.
Aug 27, 2010 | Refrigerators
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water coming out
check power at the water pump. It is two of them one for icemaker, one for water dispenser. Pump located on the back bottom left....you need a 1/4 nut driver to take bottom panel off. Check power when someone else push water dispenser botton on the front of thr fride...if it is power you have to repalece whoe assembly, if it is not you have dig in deeper in to door dispenser...any question please ask, totalcarefl@yahoo.com
Aug 23, 2009 | GE GSS20IEP Side by Side Refrigerator
Fride not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 04, 2009 | Amana ARB9059CS Bottom Freezer...
Water at bottom of frig. How do I clean the draining device and where is it? Thanks, Susan
should be behind the fride at bottom and be accesable just lift out the tray
Jun 06, 2009 | Refrigerators
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Mar 27, 2009 | Smeg FA561X Side by Side Refrigerator
MY WATER IS ALWAYS DRIPPING..HOW CAN I FIX IT?HELP
you may want to check your water presuure if pressure is to low the valve in the back of the fride is not closing properly or the valve is defective to check for this you need to remove the electric solenoid behind the fride leave the water line installed disconect the output tubingif it drips replace the solenoid valve gilles_dumais@hotmail.com
Mar 15, 2009 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
104 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
