Question about Dishwashers
Our Lamber GS900 underbench dishwasher machine did not fill the hot water anymore so we have to pour hot water manually until it reached the required level. It drains perfectly and work as it should be.
  • 68 Answers
Check the float switch. If the float is stuck or the switch is jammed or broken, the d/w will not fill.
Posted on Nov 19, 2009
Do you know if it's a hot or cold feed at inlet
Hi Charles
The traditional method of supply was using hot water for filling. However, it is possible to save money on some machines by hooking up to cold water as the element in the dishwasher uses less power than your water heater. Unfortunately, some manufacturers still require using hot water for filling. You'll need to check your manual to see if this is the case. Here's a link to This Old House explaining dishwasher installation.
Hope this helps
-Steve
How to Install Dishwasher
Mar 04, 2015 | Dishwashers
My hobart underbench dishwsaher will not fill or heat
Sound like the inlet water valve is out. So with no water it doesn't sense water to heat.
Nov 30, 2014 | Hobart Dishwashers
Instructions or Manual required
Actually every dishwasher I've worked on had one water inlet and it was always for hot water. Approximately 3 gallons per cycle.
Mar 25, 2014 | Candy 24 in. CD623 Free-standing...
Frigidaire Professional Series dishwasher started to have hot water suddenly fill up dishwasher and the pour out onto my kitchen floor. The dishwasher was not on. I had to press cancel button to get water...
I think your hot water inlet valve has failed open. It is electrically operated, and can stick in that position.
If not that, it is possible that the water level sensor signal has failed, but that should only be apparent when the washer is on.
It requires a service call.
Feb 04, 2014 | Maytag 24 in. MDB5601AWS Stainless Steel...
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
Dishes are still wet...water doesn't seem to be heating
bad water temperture. run the machine after you run the hot water faucet. add and fill jet dry .close the door lower it then raise it repeat three times then refill keep doing this until the dispenser cant hold anymore liquid. you will see a big difference.
Mar 03, 2010 | Dishwashers
Washer does not fill with water
I checked the inlet solenoid valve to make sure it was receiving power, it was. I removed the left hand side panel of the machine. The labyrinth was blocked with crud as was the float switch assy,
Cleaned them out,with boiling hot water, it now works.
Jan 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Washing machine wont fill
hmmm...wool requires cold water...I'm guessing that first the hot water and now the cold water solenoid valves have become clogged with sediment. test by turning off water. then loosen the hose connection to each inlet in back of washer. then slowly open water valves and let water pour into wash tub if hose will reach, otherwise pour into a bucket. if water comes out of hose, then look for metal screens at hose connections to washer and clean those. if still no water through solenoids (after re-connecting water hoses) then may need to disassemble solenoids and clean those too.
Oct 19, 2007 | Washing Machines
Dishwashers Logo
153 people viewed this question
Top Dishwashers Experts
