Question about Canon PIXMA iP1500 InkJet Photo Printer
My printer the head is not installed ..but it is...what di I do?
    President:
  • 787 Answers
The print head is failed and you need replace it.It's part number is QY6-0054.
Posted on Nov 19, 2009
My konica monilta di 450 is giving error code c-13fa please help and give me its solvation?
The problem is the print head that is were the LASER is located open close the front door to reset if it comes back replace the print head
Feb 01, 2014 | Minolta DI-2010F Copier
Di 450 earer coad c13f8
Print Head error. The print head is what houses the LASER for printing/copying. Open Close front door to reset. IF not replace the Print head. Worse case the image control board is bad. Also check all connections between the print head and the image control board.
Sep 14, 2013 | Minolta DI-2010F Copier
Gimana cara melepas sensor print head R230?
Butuh resetter buat R230. tidak perlu di bongkar
Dec 26, 2012 | Epson STYLUS R230 InkJet Photo Printer
PRINT HEAD failure that is the unit the LASER is in. try open close front door, check connection between print head and image control board if not need a new print head.
Dec 28, 2011 | Minolta DI-2010F Copier
Konica minolta di 1611, di 2011 driver windows 7 32 bit. konica minolta di 1611, di 2011 driver windows 7 64 bit pozdrawiam Jarek
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of BH 164 x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
Feb 10, 2011 | Konica Minolta Di2011
Kerusakan printer type Epson R 230
Trouble at main board printer. Setrum ke head ilang. Penyebabnya sebagian besar karena konselt di head. Check dulu kabel pita ke head dan sirkuit kecil di head. Kemungkinan besar yang putus adalah fuse pada main board. Tapi angel untuk diperbaiki. Kalao punya pengalaman solder (blow) bisa dicoba untuk mengganti f1 dan/atau f2 fuse. Kalau dekat dengan kota malang coba cari A&T Printer Service.
Sep 16, 2009 | Epson Stylus Photo R200 InkJet Printer
Does not print color
did you recalabrate after changing cartridges? and if you di is the color printer head bad? run the hp test software at www.hp.com to troubleshoot your problem.
Aug 13, 2009 | HP Office Equipment & Supplies
HP940C doesn't print the blue ink
Hi, the printer need nozzle check you can determine what are the problem ink cartridge. , if blue does not display in nozzle check printer need head cleaning twice.
Feb 03, 2008 | HP DeskJet 940c InkJet Printer
Configure to print
You may print without the D-Link Printer software in Windows 2000/XP. Here´s how: Step 1 Go to Start>Settings>Printers>Add New Printer (WinXP - Start>Printers and Faxes>Add a Printer). Step 2 Select Local Printer. Make sure to uncheck Automatically detect and install my plug and play printer. Click Next. Step 3 Select Create a New Port and select Standard TCP/IP port. Click Next. Step 4 Enter the IP address of the router (192.168.0.1). Leave the port name with the default name. Click Next. Step 5 You will get a message saying that additional port information required. Step 6 Select Custom and then click Settings. Step 7 Set Protocol to LPR. Step 8 For the LPR Settings, queue name is lp. It is case sensitive! (LP lower-case). In most cases, check LPR Byte Counting Enabled. If you cannot print, then try unchecking this. Step 9 Select OK > Finish. Step 10 Continue with the Add Printer Wizard. Choose your printer from the list or click Have Disk and point to your printer driver disk.
Feb 16, 2006 | D-Link DI 707P (DI-707P) Router
Canon PIXMA iP1500 InkJet Photo Printer Logo
97 people viewed this question
old marine
old marine
