In Dash Receivers
Problem for In Dash Receivers
Generic problem for all In Dash Receivers
1990 Toyota Camry antenna control vac...
By av8orjoe on Jan 11, 2008
Can anyone direct me to the vacuum line that controls the electric Antenna on this model. The old antenna bit the dust and in the process of replacing it with a non electric model, I lost the vacuum line when I removed the old antenna. The line is open and creates a vacuum leak that is causing the engine to run rough. I have tried to reach the line in the rear wheel well to no avail. If I could find which of the myriad vacuum lines on the engine goes to the Antenna, I could plug the line and eliminate the problem. Any assistance greatly appreciated.
Joe Rossman
Best Solution
posted on Jan 14, 2008
Helpful)
pierre235
Rank: Guru
Rating: 87%, 837 votes
remove the moulding on the floor when you open the door there clip holding it in place go easy not to break the moulding under the moulding you should see wires be carefull remove the tape around the wire vacuum line should be in there dont cut it right away squeeze it with pliers if the engine goes better cut it and seal the pipe cheers
Was this helpful?
Yes
No
Popular Solutions for In Dash Receivers
Questions and Unsolved Problems for In Dash Receivers
Answer
problem with motor diagnostick in my car when i install the radio
Answer
I have a `clarion RDB465D cd player and the display will not show. but the lights around the... (More)
Answer
when you turn the item on : mp822-4g screen reads please wait ( for 2 hours)
Answer
The USB port has problems with 16 GB USB flash drive. I tried with sanDisk Cruzer and Verbatim. I... (More)
Answer
i need the code for the player but don't have it.Where can i get this code
Describe your In Dash Receivers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receiver Experts
Top Audio & Video Equipment Repairmen
in , PA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
